APIC-EM PNP isues provisioning 4331
Guymarkcurtis
Hey
Has any one come accros this issue
we are trying pnp auto provision a 4331 router in our lab but on registration with apic-em it is having the following error
Received response from pnp agent for message correlatorId: CiscoPnP-1.0-5-621-7F53216FC1E8-5 but with error code : ZTD_CMD_ERROR Response String: ERROR:PnP Service Error 3300:Certificate installation not successful
this is comming from the apic-em device history
the connection process is then stalling with status of error and it never becomes an unclaimed device
we are using a boot strap config from usb to get the router to the point that it can connect to APIC-EM as it needs to bring up DMVPN tunnels to do this
i have tried updating to the latest recommended FW for the device
Thanks for any comments in advance
Guy
ngoldwat
Level 4
Level 4
Are you using vrf Mgmt-intf?  If so you need to enable http.
aradford
Hi Guy,
are you able to provide the following:
1) APIC-EM version
2) Software version(s) on the 4331
3) a sanitized version of the bootstrap config
A couple of things to look at:
1) Did you look for console  error messages in "show logging"
2) did you turn on debugging on the switch as a part of the bootstrap "debug pnp all"
Adam
leedavies-gds
I've seen this when trying pnp from a VRF.  Solved it by moving pnp to Global.  I suspect revocation checking does not recognise the VRF properly (missing "vrf" command under trustpoint) so certificate install fails.
Hi Lee, did you add the
ip http client source-interface <interface>
command as Nick suggested  You need this if you are using a vrf.
