APIC-EM REST (GET) call via PoweShell
ymeloch
Hi Team,
I'm trying to execute an APIC-EM REST (GET) call via a PowerShell script.
The APIC is self-certified hence I had to use the first bulk of code lines (the actual code is in Green color):
[System.Net.ServicePointManager]::CheckCertificateRevocationList = $false;
Add-Type @"
    using System;
    using System.Net;
    using System.Net.Security;
    using System.Security.Cryptography.X509Certificates;
    public class ServerCertificateValidationCallback
        public static void Ignore()
            ServicePointManager.ServerCertificateValidationCallback +=
                delegate
                    Object obj,
                    X509Certificate certificate,
                    X509Chain chain,
                    SslPolicyErrors errors
                    return true;
[ServerCertificateValidationCallback]::Ignore();
$Splat = @{
    Method      = 'GET'
    Uri         = 'https://10.122.6.150/api/v1/discovery/1'
    ContentType = "application/json"
    Headers     = @{authorization = "X-Auth-Token:ST-3166-nHrsi63Rbvkwze5aznoN-cas" }
$response = Invoke-RestMethod @Splat
After running the script (in PS admin window), I'm getting the following error:
Invoke-RestMethod : { "response":{"errorCode":"RBAC","message":"Failed to provide a CAS service ticket to validate","detail":"Failed to provide a CAS service ticket to validate"}, "version":"1.0"} At C:\psScripts\rest2.ps1:38 char:13
+ $response = Invoke-RestMethod @Splat
    + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-RestMethod], WebException
    + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeRestMethodCommand
The Token is working when running a query from through Postman (see screenshot)
Thanks much in advance,
Yossi
aradford
Hi Yosef,
the header is called "x-auth-token", not "authorisation".  Did you try:
Headers     = @{X-Auth-Token = "ST-3166-nHrsi63Rbvkwze5aznoN-cas" }
Adam
8 Replies 8
aradford
Hi Yosef,
Adam
Thanks for the prompt reply!
I changed that to the following and it worked well (command: https://10.122.6.150/api/v1/discovery/count)
Headers = @{“X-Auth-Token” = "ST-3166-nHrsi63Rbvkwze5aznoN-cas" }
So the updated script is:
Add-Type @"
using System;
using System.Net;
delegate
Object obj,
X509Chain chain,
return true;
::Ignore();
$Splat = @{
Method = 'GET'
Uri = 'https://10.122.6.150/api/v1/discovery/count'
Headers = @{"X-Auth-Token" = "ST-3166-nHrsi63Rbvkwze5aznoN-cas" }
Write-Host $response
Now, I wonder why I’m getting:
“@{response=; version=1.0}” when I query for https://10.122.6.150/api/v1/discovery/1
Or
“@{response=System.Object[]; version=1.0}” when I query for https://10.122.6.150/api/v1/network-device
Probably something w/ the $response statement export…
Thanks!
I changed the “Write-Host $response” to “Write-output $response” and I do see additional lines, yet, many other lines are missing…
The expected response:
And for each key:
BTW, I do know that the $response contain all the info
It looks pretty close. Not all fields will be populated.
It should match the postman output?
Adam
Since the “$response” variable contain all the date, I would think so…
Darren Starr
Level 4
Level 4
I started a Powershell for APIC-EM module today. I am building it to automate deployment of 18,000 remote sites via PnP and templates.
https://github.com/darrenstarr/APICEMPowershell
I've only been working on it for a few hours so far, but it should be able to automate the entire process of claiming new devices, filling in template variables and deploying them by this time tomorrow. I hope to add a far more advanced templating system by the same time the following day. It's all MIT license and will be available as "Find-Module -Name 'APICEMPowerShell' | Install-Module" as soon as I find a work around in PSScriptAnalyzer for handling clear text passwords as function parameters.
I'll post some coding guidelines for submitting pull requests soon.
You may or may not find the code to be a good solution for you and I would welcome contributions.
P.S. I'm doing the project for free because I needed an excuse to do it anyway. I'll also implement a PowerShell DSC resource to automate the full installation as well as some automation of management of APIC-EM once I find a good solution for rebuilding Linux ISO files on Windows. I'm experimenting with automating the process on ISE with Ubuntu subsystem for Windows.
P.P.S. I'm automating the entire process of rolling out a Windows Server 2016 and Cisco infrastructure based on Microsoft Network Controller, PowerShell DSC, Docker, APIC-EM, MS R&RAS and ISE on UCS at : https://github.com/darrenstarr/cDayZeroDeploy this too is open source.
P.P.P.S. If you're wondering why... it's bet than watching TV.
Awesome Darren,
let me know if you need any help with the APIC-EM API calls.
Adam
Super cool!
Let me know if I can help.
