APIC-EM: When 401is returned.
Ken.T
Community Member
Do you know when the status code 401 is returned?
Sometimes I get 401 when I use post pnp-project/{project-id}/device in multiple althogh the token is correct.
I guess that a synchronous API like pnp-project return 401 when a synchronous API request is sent before the previous synchronous API task is done.
I want to know there is any possiblity that APIC-EM return 401 except case that token id is incorrect.
Ken-ichi
0 Replies 0
