Bulk Import Issue
Jason_Burrell
Frequent Visitor
Frequent Visitor
I'm using the latest version of APIC-EM Version 1.3.2.37.  I downloaded the bulk import sample edit it, save, and go back to import it and nothing happens.  Just my normal bulk import screen not showing the import status.  Anyone else run into this issue?  I checked and all services are running.
Hi Benoît,
The simplest way is to use the swagger API.  From the UI, select the API button on the top right.
Then select "Network Plug and Play"
Then select "pnp-project" and then "POST pnp-project/seed-file
Finally, select "choose file" to select your seed file and then "Try it out"
Adam
5 Replies 5
aradford
Yes, I saw the same thing.
I looked at source code and there is an exception.... which explains why it is not working.
We will get this fixed.
I can use the API from swagger and it work perfectly.
Also let me know if you are interested in the API as a short term workaround.
Adam
Hi Adam,
We are using the same version of APIC-EM (1.3.2.37) and have the same issue with bulk import.
We are interested to use API as a workaround for a short term. Can you explain us how to use this solution ?
Thanks for your help.
Benoît
Hi Benoît,
Adam
Hi Adam,
Thank you very much, it works perfectly !
BR,
Benoît
aradford
BTW, it seems this is documented in the release notes.  Will be fixed in the next patch release
Release Notes for Cisco Network Plug and Play, Release 1.3x - Cisco
CSCvc53581
Bulk Import action yields no response from UI
