cisco aci automation using ansible
vijays19
Visitor
Hi All,
Am new to cisco aci automation using ansible. i am using windows 11 and installed WSL (ubuntu). then, then installed python and ansible. I got an error when i execute the below command . Please help on how to fix this issue. how can we access sandbox from virtual VM machine.
home@IBM-PF35CWE8:~/aci_ansible_learning_labs_code_samples/intro_module$ ansible-playbook -i inventory 01_aci_tenant_pb.yml
What would you like to name your Tenant?: vs_1008
PLAY [ENSURE APPLICATION CONFIGURATION EXISTS] *************************************************************************
TASK [ENSURE APPLICATIONS TENANT EXISTS] *******************************************************************************
fatal: [sandboxapicdc.cisco.com]: FAILED! => {"changed": false, "error": {"code": "400", "text": "Failed to parse login request"}, "msg": "Authentication failed: 400 Failed to parse login request"}
PLAY RECAP *************************************************************************************************************
sandboxapicdc.cisco.com    : ok=0    changed=0    unreachable=0    failed=1    skipped=0    rescued=0    ignored=0
15 Replies 15
Marcel Zehnder
Can you post the contents of your inventory file + playbook?
vijays19
Visitor
inventory
[apic:vars]
username=admin
password=!v3G@!4@Y
ansible_python_interpreter="/usr/bin/python3"
[apic]
Tenant config
name: ENSURE APPLICATION CONFIGURATION EXISTS
hosts: apic
connection: local
gather_facts: False
vars_prompt:
- name: "tenant"
prompt: "What would you like to name your Tenant?"
private: no
tasks:
- name: ENSURE APPLICATIONS TENANT EXISTS
aci_tenant:
host: "{{ ansible_host }}"
username: "{{ username }}"
password: "{{ password }}"
state: "present"
validate_certs: False
tenant: "{{ tenant }}"
description: "Tenant Created Using Ansible"
Can you test again, your files work for me.
inventory
[apic:vars]
username=admin
password=!v3G@!4@Y
[apic]
test.yml
- name: ENSURE APPLICATION CONFIGURATION EXISTS
  hosts: apic
  connection: local
  gather_facts: False
  vars_prompt:
   - name: "tenant"
     private: no
  tasks:
      aci_tenant:
        state: "present"
ouput
(default) maercu@CHLT303344:~/dev/ciscocomtest$ ansible-playbook -i inventory test.yml
What would you like to name your Tenant?: blablabla
changed: [sandboxapicdc.cisco.com]
sandboxapicdc.cisco.com    : ok=1    changed=1    unreachable=0    failed=0    skipped=0    rescued=0    ignored=0
Playbook all looks good, i think the 400 is red flag and the sandbox/API was busy - it was taking an age for the UI to load this morning. This sandbox gets a lot of use daily.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Agree, overlooked this one (tought its a 401 and some user/password issue) - but you're right, might be overload situation.
Hi @vijays19
I noticed some change in the collection version 2.7, try to explicit set the use_ssl param (will check the code of the collection to understand what's happening):
  hosts: apic
  connection: local
  gather_facts: False
  vars_prompt:
   - name: "tenant"
     private: no
  tasks:
      aci_tenant:
        state: "present"
        use_ssl: true
vijays19
Visitor
Hi Marcel,
Thanks for your response.
Do i need to remove ansible_python_interpreter="/usr/bin/python3" from inventory. from your output its not there.
Most propably you don't need it.
qsnyder
Have you installed the collection for ACI?
ansible-galaxy collection install cisco.aci
q.
vijays19
Visitor
No I didnt install it. i will do it now.
Marcel Zehnder
Looks like you installed the "batteries included" version of ansible with the aci collection already included - the galaxy install is only needed, if you install only the ansible-core version. But anyway, Quinn's input is valid - upgrading the collection won't hurt:
ansible-galaxy collection install cisco.aci --upgrade
As of Ansible 2.10 (which was released about 5 years ago) -- Ansible no longer includes external modules.
If the OP installed a fresh version of Ansible without statically setting the version in the installation or requirements file -- then he needs to install the collection.
Marcel Zehnder
Yeah I know that, Quinn. Sorry I should have been more precise: I was refering the ansible version installed via pip (pip install ansible vs. pip install ansible-core). The "normal" python package (aka the ansible community package - which is installed via pip install ansible) still includes the most common collections including ACI (https://pypi.org/project/ansible/).
