Cisco Catalyst SD-WAN: Identifying Primary and Backup cEdge/vEdge
Prodrick
Using the SD-WAN Bulk API, how might one identify if the Edges for a given site are highly available and which one is primary vs secondary/backup?
I dont see a defined API for High Availability in the docs, best guest it would be in the State bulk API operations. I would check this space also SD-WAN Community
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
