Cisco Prime API: # of connections per SSID
JanJanus58934
Hello All
1. What is the best way to pull # of connections per last 24 hours?
It took 3-4 hours to get everything out of "/v3/data/HistoricalClientCounts.json?.full=true&id=gt(target)&.maxResults=1000" using paged request.  I can alter the get request in a way which would enable me to pull info about specific SSIDs but I guess it will take hours to get the total # of connections and the .json output would be unreadable anyway. Is it possible to leverage DB access instead of API? The DB holds the data anyway as it present in GUI.
2. Is it possible to # of connections for past week/month
Thank you
Best regards,
Jan
Alexander Onnikov
Hi Jan,
If you need to get only number of connections then you can modify API request as following:
/v3/data/HistoricalClientCounts.json?id=gt(target)&.maxResults=1
This query will return only one entity without any details. Response will contain total number of connections as "@count" attribute of "queryResponse" object:
{"queryResponse":{"@last":0,"@first":0,"@count":2853,"@type":"HistoricalClientCounts","@requestUrl":"https://pi/webacs/api/v3/data/HistoricalClientCounts?id=gt(1)&.maxResults=1","@responseType":"listEntityIds","@rootUrl":"https://pi/webacs/api/v3/data","entityId":[{"@type":"HistoricalClientCounts","@url":"https://pi/webacs/api/v3/data/HistoricalClientCounts/1451250","$":"1451250"}]}}
It is not possible to obtain # of connections for past/week month as this data is stored in database only for 24 hrs. After that it is completely removed.
I wonder how many clients and connections per day? It is expected that this API should not take 3-4 hrs to return data. What is your PI version?
