Issue creating Sample Loopback Interface Script Using OpenConfig!!
sindhujit
Frequent Visitor
Frequent Visitor
I am trying to create and run the openconfig script which is shown as a sample in DevNet tutorial NETCONF/YANG on Nexus Part 3: Using OpenConfig YANG Models on Nexus Switches. The file as an example is add_oc_loopback.py.
The file contents are :
#!/usr/bin/env python
from ncclient import manager
import sys
from lxml import etree
# Add parent directory to path to allow importing common vars
sys.path.append("..") # noqa
from device_info import sbx_n9kv_ao as device # noqa
# Loopback Info - Change the details for your interface
loopback = {"id": "98", "ip": "10.98.98.1", "prefix": "24"}
# create a main() method
def main():
    Main method that adds loopback interfaces
    add_oc_interface = """<config>
    <interfaces xmlns="http://openconfig.net/yang/interfaces">
        <interface>
            <name>lo{id}</name>
            <config>
                <description> Configured using OpenConfig Model </description>
                <name>lo{id}</name>
                <type>ianaift:softwareLoopback</type>
            </config>
            <subinterfaces>
                <subinterface>
                    <index>0</index>
                    <ipv4>
                        <addresses>
                            <address>
                                <config>
                                    <ip>{ip}</ip>
                                    <prefix-length>{prefix}</prefix-length>
                                </config>
                                <ip>{ip}</ip>
                            </address>
                        </addresses>
                    </ipv4>
                </subinterface>
            </subinterfaces>
        </interface>
    </interfaces>
    </config>""".format(id = loopback["id"], ip = loopback["ip"], prefix = loopback["prefix"])
    # print(add_oc_interface)
    with manager.connect(host = device["address"],
                         port = device["netconf_port"],
                         username = device["username"],
                         password = device["password"],
                         hostkey_verify = False) as m:
        # Add the loopback interface IP
        print("\nNow adding IP address {} to interface lo{} on device {}...\n".format(loopback["ip"],
        loopback["id"],
        device["address"]))
        netconf_response = m.edit_config(target='running', config=add_oc_interface)
        # Parse the XML response
        print(netconf_response)
if __name__ == '__main__':
    sys.exit(main())
Could not attach it as it was saying
The contents of the attachment doesn't match its file type.
The error I get after changing the parameters to my switch IP, user,pwd , etc. is :
Element 'config': This element is not expected. Expected is one of ( {urn:ietf:params:xml:ns:netconf:base:1.0}default-operation, {urn:ietf:params:xml:ns:netconf:base:1.0}test-option, {urn:ietf:params:xml:ns:netconf:base:1.0}error-option, {urn:ietf:params:
I changed to include
<rpc message-id="101"
          xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
         <edit-config>
         <target>
           <running/>
         </target>
However, I get another error:
Element [{urn:ietf:params:xml:ns:netconf:base:1.0}rpc] does not meet requirement
Please help or advise!!
0 Replies 0
