Connection Error while installing APIC-EM
Ionela.Onceru
Visitor
Hi, I am receiving this error several times while trying to install APIC-EM.
Do you know how to resolve this?
ngoldwat
Level 9
Level 9
What it is telling you is that the port 14141, used for management is refusing connections.
This seems like a strange error to be the culprit behind being unable to install...
Please login to APIC-EM as the grapevine user at the command line.
Execute 'tar czvf logs4cisco.tgz /var/log/installer/`
Then please attach the results.
ddeitsch1
Level 2
Level 2
Is this a single host deployment or multiple? If multiple, is this server 2 or 3? if it is not the first server, is there a firewall in between?
ngoldwat
Level 9
Level 9
Did you solve the issue?
No. Finally I have installed on another machine with necessary resources, and it works! Thank you for your answer!!
