Create VPC using acitoolkit
sinan.polat
Community Member
I have read the acitoolkit documentation at http://acitoolkit.readthedocs.io/en/latest/ but unfortunately I couldn't find any information regarding creating a Virtual PortChannel.
Suggestions / tips are highly appreciated. Thanks!
8 Replies 8
arikgelman
Level 3
Level 3
I also have the same problem, I found this:
https://github.com/datacenter/acitoolkit/blob/master/samples/aci-demo-portchannel.py
It works for standard PC but not for VPC and I also wasn't able to find how to create VPC that is associated to VMM domain.
Please help,
Arik
Yep.
saw this in the docs.
In the acitoolkit, VPCs are also represented by the PortChannel class.
however like you said, the PCs are created from this attribute but nothing on VPC.
I tried to use the API inspector,.
Using the GUI is does create VPC but trying to send the same API call creates PC and not VPC
trompa99
Same here,
from the docs, its "seems" as if we use.. from acitoolkit.acitoolkit import interface, we should see it in (dir) I can create PCs all day long however missing that 1 little piece.
arikgelman
Level 3
Level 3
Did you find an answer to this issue?
Arik
nope
I think I found the solution.
If you take the port channel example from the acitoolkit:
And do in the end:
resp = session.push_to_apic(pc.get_url()[0],
                                    pc.get_json()[0])
        if not resp.ok:
            print('%% Error: Could not push configuration to APIC')
            print(resp.text)
resp = session.push_to_apic(pc.get_url()[1],
                                    pc.get_json()[1])
        if not resp.ok:
            print(resp.text)
It works....
arikgelman
Level 3
Level 3
Any news regarding this issue?
