Creating EPG in MSO using PATCH method
shamax_1983
Level 7
Level 7
Hi Guys,
Can someone give me an example snippet of creating an EGP in MSO using Patch method (I am using Postman)?
I have been trying this but keep getting the following error no matter what I do.
I can create BDs fine, only getting the following error when trying to create EPGs using PATCH method.
Any help would be much appreciated.
MSO Version: 3.2.1f
Here's what I'm trying,
Running API calls agains :
https://{{mso-ip}}/api/v1/schemas/603ed1ed650000e38f7244dd
Body:
"op": "add",
"path": "/templates/Stretched/anps/testANP2/epgs/-",
"value": {
    "name": "myEPG",
    "displayName": "MY EPG",
    "contractRelationships": [],
    "subnets": [],
    "uSegEpg": false,
    "uSegAttrs": [],
    "intraEpg": "unenforced",
    "proxyArp": false,
    "preferredGroup": false,
    "selectors": [],
    "bdRef": "/schemas/603ed1ed650000e38f7244dd/templates/Stretched/bds/myBD"
Result.
    "code": 400,
    "message": "Bad Request: (1)(7)/epgs(0)/schemaId error.path.missing"
Ruben Cocheno
@shamax_1983
Just following up on this and see if you still need help?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
