Debbuging PnP process
JPvisltgb
Level 3
Level 3
Hi All,
I can't find any information about how to debug failed PnP proccess, where is log files stored and so on .
I'm trying to deploy config on ISR router and getting:
Received response from pnp agent for message correlatorId: CiscoPnP-1.0-16-320-7FA078EAB2A8-14 but with error code : ZTD_CMD_ERROR Response String: ERROR:PnP Service Error 1410:Invalid config found
service log:
I understand that  there is mistake in config file, but maybe there is a way to find out where exactly this mistake is  ?
I found workaround.
I've used Denali-16.3.4(ED) image on router and my config failed to install, but today I tried to change it to 3.16.5S and config deployed successfully.
13 Replies 13
aradford
I usually just cut/paste the config into the console to test.
Do you have a  "service log" command in the configuration?
Adam
No, I don't have this command. The problem is that I created config on router and then  I just uploaded it to Apic-em and now trying to deploy it via Pnp
ok.  To access log files:
ssh to the console of the APIC-EM
# find the IP address of the pnp service
$ grape instance status | grep pnp
pnp-service                          5.17.31.211  running      59621988-fdc9-4788-957c-7bdbb7de0922  169.254.0.184  9:32:39
$ ssh 169.254.0.184
# the number for you will be different.
$ cd /var/log/grapevine/services/pnp-service/5.17.31.211/
# pnp-service.log has all of the logging.
$ ls
pnp-service.log
I found it. However there is no useful information, just same message that I posted in my question.
I got info from router:
show pnp task
------------------ show pnp tasks ---------------------
Certificate-Install Task - Last Run ID:2, ST:7201, Result:Success, LT:94182, ET:3338 ms
        Src:[http://pnpserver.domain.com:80/ca/pem], Dst:[pnplabel]
Device-Auth Task - Never Run
Device-Info Task - Never Run
Image-Install Task - Never Run
SMU Task - Never Run
Config-Upgrade Task - Last Run ID:5, ST:5202, Result:Failed, LT:545313, ET:6806 ms
        Src:[https://pnpserver.domain.com:443/api/v1/file/onetimedownload/7efee699-39bf-47bb-af21-9202921cbe], Dst:[running]
        Error Code:1410, Msg:[Invalid config found]
CLI-Config Task - Last Run ID:3, ST:5201, Result:Success, LT:156998, ET:84 ms
        Src:[cli-config request], Dst:[running-config]
Licensing Task - Never Run
File-Transfer Task - Never Run
Redirection Task - Never Run
CLI-Exec Task - Last Run ID:1, ST:5401, Result:Success, LT:80463, ET:3 ms
        Src:[cli-exec request], Dst:[running-exec]
Script Task - Never Run
As i understand this error tells that it trying to get config from apic-em but failed. It is not my config problem.
Am I correct ?
What version of APIC-EM is this?  We now check for "special characters" but may not catch all of them.
Do you accidentally have special characters in your config file?
Were you using a windows device to edit the config file?
APIC-EM Version 1.5.0.1368.
PnP 1.5.0.211
Config has special chars in commands:
enable secret 5 hashed secret
username admin secret 5 hashed secret
those are ok.. You probably should delete that information.
you can edit your post and remove it.
By special characters, I mean things like windows smart quotes or '\r' type sequences.
What did you use to edit the configuration file?
I found workaround.
interesting.. let me chat to engineering about that.
What device were you running this on?
cisco ISR4321/K9
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     FoundationSuiteK9     Permanent      FoundationSuiteK9
securityk9
appxk9
For example with this command
mpls ldp tcp pak-priority it fails on Denali software.
Thanks.
Just to clarify are you saying the configuration file has differences between 16.3.4 and 3.16.5S?
e.g. mpls ldp pak-priority is in your config file and the does not work on 16.3.4.
Or that the PnP process does not work correctly in 16.3.4?
Adam
No, I was using same config with these two versions.
When I was trying to find problem  I started to remove some configuration lines.
Manually pasting this line mpls ldp pak-priority is showing Notice message so I decided to remove it first.
But this line pasted on 3.16.5S showing the same message, but pnp process is not stopping on it.
