Device Errors Out While Pushing Config
shawn.dandridge
Community Member
I always get an error on the status but apic em pushes the device. I get the following error message but the config is pushed to the device. Any ideas?
Received response from pnp agent for message correlatorId: CiscoPnP-1.0-17-494-3A341458-17 but with error code : ZTD_CMD_ERROR Response String: ERROR:PnP Service Error 1410:Invalid config found service log: % You already have RSA keys defined named RACTest41.rto.raccorp.corp. % They will be replaced. % The key modulus size is 2048 bits % Generating 2048 bit RSA keys, keys will be non-exportable... [OK] (elapsed time was 7 seconds) A pre-shared key for address mask 61.99.95.70 255.255.255.255 already exists! A pre-shared key for address mask 61.99.95.71 255.255.255.255 already exists! GigabitEthernet0/1 is already a backup for Serial0/0/0.333 % BGP: Incorrect network or mask/prefix-length configured % BGP: Incorrect network or mask/prefix-length configured
aradford
It looks like you have a certificate you are trying to push to the device?
APIC-EM has a built-in CA.
PnP will allocate and push a certificate to the device as part of the provisioning process.
It also looks like you have a config issue with your BGP.
