Device stuck in pending Apic-em
Knutsen2004
Im running a setup with Prime Infrastructure and Apic-em and Im having a issue when deleting a PnP profile on PI the device is still in pending mode on Apic-em server and im not able to add the device to the PnP profile again.
Is there a command to clear the device in project on Apic-em ?
Apic-em version 1.6.0
Pi version 3.1
Seb Rupik
Have you tried using the APIC-EM API? you don't even need to write an external script. Just use the API documentation on the APIC-EM webGUI.
Find the project UID:
/pnp-project
List the devices under the project:
/pnp-project/{projectId}/device
Then delete the device from the project:
/pnp-project/{projectId}/device/{deviceId}
cheers,
Seb.
