devnet sandbox for ACI with l2out/l3out
matthewoncisco
I would like to test out the aci with l2out , l3out scenarios.The topology i see is fixed with spines, leafs and APICs.  i dont see an option to add a regular switch /router to the topology to test out l2/l3 out?
Ruben Cocheno
@matthewoncisco
this sandbox has some limitations
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
@matthewoncisco this is correct, the sandboxes (for the most part) are prebuilt topologies which does not allow you to add or modify this design. I am not sure if the CML sandbox would meet your requirements, but pretty sure this does not contain ACI.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
mfr-6
@matthewoncisco
I believe ACI in devnet sandbox is just a "ACI Simulator" that has no dataplane capabilities thus you cannot test and forward traffic through the simulated switches.
Mateusz Frak NetDevOps | DevNet | Automation DevNet Expert #20240068
Please mark this post as helpful if it solves your issue, to make this visible for other users, thank you!
Ruben Cocheno
@matthewoncisco
