DNA Spaces - Invalid Location Hints
Endy00000
Frequent Visitor
Frequent Visitor
We're trying to implement patient tracking at one of our buildings using aeroscout. We need to have the correct network hierarchy laid out. I'm having an issues adding the "Floors" container after the "Building" container. When i try to add a floor, it says "Invalid Location Hints".
What does that mean? I thought maybe fixing the location data on item above would correct it. But it hasnt seemed to fix it.
Geevarghese Cheria
To get more idea did you had chance to try any use case demo mentioned in this url -https://spaces.cisco.com/smart-healthcare/
Alexander Stevenson
Are you using the dashboard or the API?
