How to feed device login credential to Terraform or Ansible securely?
SIMMN
Say we have three admins who would login to the linux server running Terraform and Ansible to see the source files and execute. But I do not want any of them to see the networking device login credential.
For example, I want to automate configuration backup of a network built with 4 NXOS switches. I can get Terraform or Ansible playbook written properly. But I kinda having difficult time to figure out how to protect the nexus login credential which would be fed into the Terraform or Ansible during run time.
With Ansible, I could use Vault to encrypt the nexus login credential but I still need to supply the encryption key/password to perform decryption during playbook run...Without anyone to enter the key, I could put the encryption key into a file but how am I supposed to set the permission of the file to prevent others viewing the content while still maintain the automationn? If I set owner of the file to be root or a special group, then the execution of `ansible-playbook` would need `sudo`...
With Terraform, not clue so far...
Alexander Stevenson
I'm not exactly sure how to implement this, as I haven't run into this yet, but here are some potential options:
HashiCorp Vault
https://www.vaultproject.io/
Digital Ocen
https://www.digitalocean.com/community/tutorials/how-to-protect-sensitive-data-in-terraform
terraform-provider-ansiblevault
https://meilleursagents.github.io/terraform-provider-ansiblevault/
Sharing sensitive variables between ansible and terraform (Proof of Concept)
https://medium.com/@V_Voronenko/sharing-sensitive-variables-between-ansible-and-terraform-9d3316a88b93
Thanks for the links. But they would still require minimum human inputs. For example, what if I want to schedule an ansible plan or terraform apply @ 1am every Sunday to login to all devices to perform configuration backup, I would not want to have someone to manually type in the credential to kick start the job while I still want to keep the credentials invisible...
Using Ansible Tower or Ansible AWX you can inject an 'Approve/Deny' button for a workflow/playbook.
How to add approval steps to Ansible Tower workflows
@JesseRussell08468 is correct, as AWX/Tower (AWX is the open-source version of Tower) provides role-based access control (RBAS). There has even been an effort to extend this capability for AWX to Terraform: https://github.com/mauromedda/terraform-provider-awx
Also, see 'awx Provider', which is an Ansible Tower Provider for handling Tower Projects with REST: https://registry.terraform.io/providers/nolte/awx/latest/docs
