Error APIC EM Installation (Cassandra DB)
achmad.nazmy
Community Member
We are installing APIC EM in our VM Lab. But we are facing an error with the installation after completing the config wizard. It seems to be a problem with cassandra DB. Below is the stack trace:
2015-04-15 06:57:04,083 | DEBUG  | 32207 | ShellCmdThread-561552 | 140248664151808 | gr
apevine.common.shell.ShellCommand.ShellCommand   | ShellCommand.py:99 | Command '/opt/cis
co/grapevine-db/cassandra/bin/nodetool -h 192.168.16.1 netstats' finished (ret: 2)
=== stdout ===
Mode: STARTING
Not sending any streams.
=== stderr ===
error: org.apache.cassandra.db:type=StorageProxy
-- StackTrace --
javax.management.InstanceNotFoundException: org.apache.cassandra.db:type=StorageProxy
    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getMBean(DefaultMBeanSer
verInterceptor.java:1095)
    at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.getAttribute(DefaultMBea
nServerInterceptor.java:643)
    at com.sun.jmx.mbeanserver.JmxMBeanServer.getAttribute(JmxMBeanServer.java:678)
    at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.ja
va:1464)
    at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.jav
a:97)
    at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConne
ctionImpl.java:1328)
    at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnect
ionImpl.java:1420)
    at javax.management.remote.rmi.RMIConnectionImpl.getAttribute(RMIConnectionImpl.j
ava:657)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.j
ava:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:322)
    at sun.rmi.transport.Transport$2.run(Transport.java:202)
    at sun.rmi.transport.Transport$2.run(Transport.java:199)
    at java.security.AccessController.doPrivileged(Native Method)
    at sun.rmi.transport.Transport.serviceCall(Transport.java:198)
    at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:567)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:82
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.access$400(TCPTransport.j
ava:619)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler$1.run(TCPTransport.java:6
84)
81)
    at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:681
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615
    at java.lang.Thread.run(Thread.java:745)
    at sun.rmi.transport.StreamRemoteCall.exceptionReceivedFromServer(StreamRemoteCal
l.java:275)
    at sun.rmi.transport.StreamRemoteCall.executeCall(StreamRemoteCall.java:252)
    at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:161)
    at com.sun.jmx.remote.internal.PRef.invoke(Unknown Source)
    at javax.management.remote.rmi.RMIConnectionImpl_Stub.getAttribute(Unknown Source
    at javax.management.remote.rmi.RMIConnector$RemoteMBeanServerConnection.getAttrib
ute(RMIConnector.java:906)
    at javax.management.MBeanServerInvocationHandler.invoke(MBeanServerInvocationHand
ler.java:267)
    at com.sun.proxy.$Proxy13.getReadRepairAttempted(Unknown Source)
    at org.apache.cassandra.tools.NodeProbe.getReadRepairAttempted(NodeProbe.java:944
    at org.apache.cassandra.tools.NodeTool$NetStats.execute(NodeTool.java:612)
    at org.apache.cassandra.tools.NodeTool$NodeToolCmd.run(NodeTool.java:247)
    at org.apache.cassandra.tools.NodeTool.main(NodeTool.java:161)
Can please advise what the root cause is? Do we did something wrong with the configuration?
Nazmy
Hi Nazmy,
Thanks for the files. Our dev team took a look and found the same IP address is configured on both of the root VM interfaces. Please run the config to correct that.
eth0  Link encap:Ethernet  HWaddr 00:50:56:a7:b4:bc
      inet addr:192.168.168.97 Bcast:192.168.168.255  Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:6233 errors:0 dropped:0 overruns:0 frame:0
      TX packets:235 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:513013 (513.0 KB)  TX bytes:20534 (20.5 KB)
eth1  Link encap:Ethernet  HWaddr 00:50:56:a7:e7:bc
      RX packets:6847 errors:0 dropped:68 overruns:0 frame:0
      TX packets:716 errors:0 dropped:0 overruns:0 carrier:0
      RX bytes:566677 (566.6 KB)  TX bytes:388742 (388.7 KB)
eth1 interface should have an IP from public network - different than that from the private network IP assigned to eth0.
yawming
Hi Nazmy,
Did you see this on console after finishing the last step of config wizard ?
Yawming
In order to look into more detail can you please collect a RCA bundle of the cluster for further analysis?
How to create a RCA bundle ?
  • ssh into the root VM
  • Run the "rca" command
  • Send us the resulting RCA tarball that is created
If file is too big please put it in dropbox or box and share the link.
Yawming
Hi Yawchen,
Thanks for your response.
The error is not displayed in the console. I get the error message from grapevine_config_wizard.log.
Please download the RCA tarbal from the URL below:
Dropbox - grapevine-root-192.168.168.97-rca-2015-04-15_08-01-30-AM_UTC+0000.tar.gz
Nazmy
Hi Nazmy,
