Got stuck while doing vCenter configuration for APIC-EM EFT2
sagar.varpe
Community Member
Hi All,
            I am trying to do setup of APIC-EM EFT2. This version requires a VMWare VCenter configuration.I have installed vCenter and while doing host configuration we are getting following error.
I have attached screenshot below. Thanks in Advance.
Geevarghese Cheria
Hi Sagar,
Which version of APIC-EM are you using? if its Version 0.7.1.3 Can you try with  Hypervisor—VMware vSphere versions 5.1 or higher.You access the console using any of the root VM IP addresses that you entered . Can you try http://root-vm-IP-address:14141. and let us know the result.
Thanks and Regards,
Geevarghese
Hi Greevarghese,
    Thank you for your quick response. I am using APIC-EM version apic-em-root-CA-1822-0.1.0.510 . I have just load VM but haven't done any configuration for it. And while doing configuration it has mandatory vCenter host details. As we are stuck while doing installation onf vCenter. So we can not complete APIC-EM configuration setup yet, The URL you are saying, will it with out completing APIC-EM configutation?
Hi Sagar,
    I haven't tried the  apic-em-root-CA-1822-0.1.0.510 . version. what I understand is that once you set the vCenter Account Permissions then only you will be  able to  deploy the .ova file which you have downloaded. I think APIC-EM is being deployed from a single OVA file and during the deployment multiple VMs on multiple hosts need to be created and hence must be done from within vCenter.so Deploying APIC-EM  from OVA using a vSphere client will fail. hope this helps.
Thanks and Regards,
Geevarghese
yawming
Most likely is your network issue. Make sure the external network IP address you used can communicate with you vCenter.
Which document you followed to do the configuration ?
