How can I practice Ansible without physical gear?
rahaisley
The subject line pretty much says it all.
I want to know if it's possible to practice network configuration with Ansible using only emulation/simulation software.
How can I go about setting up something like this because I have no physical gear?
Alternatively, if there is any resource out there that explains this, please send me the link.
you can use software such as GNS3 or EVE-NG for emulating the devices virtually.
https://www.gns3.com/
https://www.eve-ng.net/
Good luck
KB
@rahaisley you can use the CML sandbox for free https://devnetsandbox.cisco.com/RM/Diagram/Index/685f774a-a5d6-4df5-a324-3774217d0e6b?diagramType=Topology
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
