IWAN: "Error while reserving Ips for flow 1" or "Failed to reserve a when adding Branch router
APIC-EM 1.2.0.1594
I'm trying to add a branch to IWAN and I keep getting a "Error while reserving Ips for flow 1" message when I try to apply changes on the Branch page.
The hub site is configured for 60 sites and the Generic IP pool is a /22.
I'm using specific address pools for the routers.
The Generic pool is showing 79% allocated and there is only one other branch router configured so far.
I experimented with adding a LAN interface pool and making a specific pool but no dice.
Any ideas? Perhaps I need to clean up the address pool because of failed attempts etc?
The other error message is "Failed to reserve sufficient number of IPs" when I don't use the specific pool.
The LAN interface pool is a /16 right now, I have also added a /12 as well but no difference.
Which version os APIC-EM are you running? Can we access the cluster? If yes, please provide access credentials.
If not, please collect the RCA and send to iwan-controller-dev; we'd be happy to help.
