Prime 3.4 Complaince Job - Fix Inputs
Jason Mann
I am having trouble getting the Rules Input variable to work correctly. I have selected Fix for the scope and included the variable in my cli fix screen but when I try to run the fix for the compliance job I just get "Fix Input not available" I have included some screenshots. Anyone ran into this or know how to fix?
Jochen Reinecke
Hi Jason,
you can use variables with input if u are using ^ in front and at the end of the variable. Example:
^<_VAR>^
As you can read in the Compliance Guide:
Fix CLI
Note This field is available only if you selected User defined Violation Message in the Violation Message Type field.
Enter a relevant CLI fix if the device does not meet the condition specified. Do not enter config t , configure , and its exit commands. Rule inputs and Grep outputs can be used here.
Note The exit command is allowed in main and sub-level commands.
Following are the formats for the CLI fix that you enter in this field:
  • For an execution type input, enter <Rule input ID>
  • For a fix type input, enter ^<Rule input ID>^
  • For a grep type output, enter <n.m>, where n is the condition number and m is the output number.
Hope that helps.
Best regards,
Jochen
best regards,
