Prime Infrastructure and APIC-EM PNP
dasampson
Hey Everyone,
This is probably the wrong forum for this post, please redirect me if this is so.
I am trying to implement the Plug and Play ability with APIC-EM and Prime Infrastructure.  We have being using Prime Infrastructure but have only recently added APIC-EM to our environment.  I have joined Prime to APIC-EM and vice versa.  It appears the Prime and APIC-EM are sync'd succesfully.
When in Prime, I try to create a Plug and Play profile for either Routers or Switches and I get an error message saying, "Failed - Site Creation is failed. null" when I try to Save New Plug and Play Profile.  Any ideas what is going wrong?
Our Prime Infrastructure version is 3.3 and APIC-EM Version 1.6.0.30151.
Thanks for any help that can be provided.
Dave
Geevarghese Cheria
Hi David,
Apologies for delay in responding to you. Please find this url - Video Link : 13949 for related information. Moving your question under Prime Infra community for more visibility of support engineers.
Thanks and Regards,
Geevarghese
karien.verster
Hi dasampson,
I am having the exact same issue, just with version 3.4 on PI.
Did you ever get your issue resolved?
It turned out to be that I didn't have the Plug and Play feature loaded in APIC-EM.  I can't access our APIC-EM at the moment to give you the exact area to go to install the feature.  If you need this information, please  reply and I will take a look when I get back to the office next week.
Turns out that was my issue too.  I was totally under the impression that the pnp feature would be built in from the start.
Got it sorted out now,
Thank you very much
