Python IDE for Cobra development
timwukp
Community Member
HI Cobra Guru,
May I know which IDE you will suggest for Cobra SDK development? E.g. Eclipse? Thanks
Rgds,
Tim
timwukp
Community Member
Thank you Michael.
I am using Eclipse Pydev plugin. will try PyCharm
taoli
Which OS do you use? Mac OS, or Windows,/ Linux ?
Eclipse is good IDE tool on Mac OS.
michsmit
A number of folks are using PyCharm
timwukp
Community Member
Thank you Michael.
taoli
I installed the PyCharm Community Edition 4 . It need Java 6 on MacOS.
I tested the acitoolkit , it's ok.
