Removing Contracts and FilterEntries
irocha001
  As shown in aci_demo_contract.py, I was able to create a new contract and setup several filters as well. When I try to remove a contract or filter, using mark_as_deleted() and pushing to APIC, everything work as usual but in the Secutity Policies -> Filters the property created with <contract name> + <entry name> is not removed. See below:
contract = Contract('mysql-contract', tenant)
entry1 = FilterEntry('entry1',
                     applyToFrag='no',
                     arpOpc='unspecified',
                     dFromPort='3306',
                     dToPort='3306',
                     etherT='ip',
                     prot='tcp',
                     sFromPort='1',
                     sToPort='65535',
                     tcpRules='unspecified',
                     parent=contract)
<push to APIC>
entry1.mark_as_deleted()
contract.mark_as_deleted()
<push to APIC>
After that, inside Secutity Policies -> Filters I still get 'mysql-contractentry1'. What should I do to remove all the entries related to my contract?
Thanks in advance,
   Ivan Rocha
davbark2
Hi Ivan,
Sorry your question has been neglected for so long.
If it still matters,  using entry1.mark_as deleted()  only deletes an entry in that filter, but not the filter itself.  I think you want to use the following instead, to remove the filter and any entries it contains, along with the contract:
filter = entry1.get_parent()
filter.mark_as_deleted()
Hope that helps,
Dave
