/v2/map/floor/:floorId doens't work
schuurman
I'm testing out the V2 api's and the /v2/map/floor/:floorId doesn't work.
"code": 5000,
    "message": {
        "status": 404,
        "message": "Error calling end point: http://internal-mapservice.eu-prod.dnaspaces.io:80/api/maps/v2/location/floor/:floorId?tenantId=mytenantId. Status code: 404"
All the other API's that I try work.
Any suggestions?
Torbjørn
Hello @schuurman, Welcome to the community!
You should substitute :floorId with your floor id such that your url will look like this: https://dnaspaces.eu/api/location/v2/map/floor/{putYourFloorIdHere}
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
