BasharAziz
Example Configuration: Let's consider a scenario where we need to create a loopback interface with an IP address and description on a router named 'router00' using the NSO (Network Service Orchestrator) management system.
  1. Initial Configuration: We start by configuring the loopback interface with the desired IP address and description
    admin@ncs# config
    Entering configuration mode terminal
    admin@ncs(config)# services basic-service router00 int-name 123 loopback-ip 1.1.1.1 loopback-description main-int hostname ios-router
    admin@ncs(config-basic-service-router00)# commit dry-run outformat native
    native {
      device {
        name router00
        data hostname ios-router
        interface Loopback123
          ip redirects
          description "main-int"
          ip address 1.1.1.1 255.255.255.255
          no shutdown
        exit
    Commit complete.
  2. Successful Deployment: The configuration is successfully applied to the router 'router00':
    router00# show running-config interface Loopback 123
      no shutdown
    exit
    router00#
    Addressing Out-of-Sync Issues: Now, let's explore different scenarios to demonstrate how the 'no-overwrite commit' flag handles out-of-sync issues effectively.Changing Loopback IP Address: We attempt to change the IP address of Loopback123 on the router:
  3. Changing Loopback IP Address: We attempt to change the IP address of Loopback123 on the router:
    router00(config)# interface Loopback123
    router00(config-if)# ip address 2.2.2.2 255.255.255.255
    router00(config-if)# commit
    Commit complete.
  4. Out-of-Sync Detection: When we check the synchronization status using the NSO 'check-sync' command, we observe an 'out-of-sync' alarm:
    admin@ncs# devices device router00 check-sync
    result out-of-sync
    info got: 96b592b1356b7c339d3e3cda08a022f2 expected: e57de8d6d861d77af042ec30a54f26cc
    admin@ncs# *** ALARM out-of-sync: got: 96b592b1356b7c339d3e3cda08a022f2 expected: e57de8d6d861d77af042ec30a54f26cc
    admin@ncs#
  5. Using 'no-overwrite' to Address Out-of-Sync: By making changes to the loopback description and using the 'no-overwrite' flag, we can prevent overwriting the out-of-sync configuration:
    admin@ncs(config-basic-service-router00)# loopback-description main-int-changed-by-nso
    admin@ncs(config-basic-service-router00)# commit no-overwrite
    Commit complete.
  6. Successful Deployment: The configuration is successfully applied to the router 'router00':
    no shutdown
    exit​
  7. By manually making changes to the loopback description direct on the router:
    router00# config
    router00(config-if)# description main-int-changed-by-admin
    Commit complete.
  8. By making changes to the loopback description with NSO and using the 'no-overwrite' flag, we can prevent overwriting the out-of-sync configuration:
    admin@ncs(config-basic-service-router00)# loopback-description main-int-changed-by-nso-one-time-more
    Aborted: Network Element Driver: device router00: out of sync: for 'devices device router00 config interface Loopback 123 description'
1 Comment
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
