Hiro Takahashi
Introduction
This blog is a quick note how to setup NSO PnP server with a physical ISR device to demonstrate ZTP.
Following is summary of the demo:
  1. Restart ISR with an empty config
  2. ISR obtains IP address by DHCP option 43
  3. ISR connects to NSO via PnP
  4. NSO configures ISR with day 0 config through PnP
  5. NSO adds device, fetches SSH key and does sync-from
Note, this document covers day 0 config only (not day 1 by using reactive FASTMAP).
Topology
Tested with NSO 4.4.2.1 and cisco-pnp-project-1.9.0.
Get a serial number
NSO identifies each device by its serial number.
Because of that, you must know a serial number by "show version" command.
In following case, serial number is FGL27131376.
ISR891#show ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.6(3)M1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Fri 02-Dec-16 15:28 by prod_rel_team
(snip)
Device#  PID SN
*1    C891FJ-K9             FGL27131376
Configurations
A Cisco router, act as DHCP server, has following configuration.
ip dhcp excluded-address 10.0.1.1 10.0.1.100
ip dhcp pool nso
network 10.0.1.0 255.255.255.0
domain-name cisco.com
option 43 ascii 5A1N;K4;B2;I10.0.1.20;J9191
Option 43 string means following.
5 - DHCP sub-option. PnP is five.
A - Active, means client must connect to PnP server. This must be Active.
1 - Version 1
N - Debug off
; - delimiter
K4 - Use HTTP
B2 - Use IPv4
I10.0.1.20 - IP address of PnP server. NSO IP address.
J9191 - NSO port
NSO must have at least Cisco NED and PnP package.
To install PnP on NSO, download ncs-4.4.2.2-cisco-pnp-project-1.9.0.tar.gz from CCO.
It contains following files.
  • doc
  • init_data
  • packages
  • project-meta-data.xml
Under packages directory, find ncs-4.4.2.2-cisco-pnp-1.9.0.tar.gz and untar the file to your packages directory.
After doing "packages reload" on NSO, configure follwiing PnP configurations.
admin@ncs# show running-config pnp
pnp server ip-address 10.0.1.20
pnp server port 9191
pnp server use-ssl false
pnp logging serial all
pnp map FGL27131376
device-name  ISR891
username     cisco
password     $8$nV2GkQf9XvBPbsPhasJWVjWxYxiU1gF1KCFKzec/bvU=
sec-password $8$tfJCjJhVLzayEVr+U3Ee1AxWtaAeX6a9N0EtgU4vWYs=
device-type  cli
ned-id       cisco-ios
port         22
day0-file    ISR891.txt
cfg-properties variable HOSTNAME
  value ISR891
Following is output of ISR891.txt under packages/cisco-pnp/cfg directory.
hostname $HOSTNAME
enable password cisco
ip domain name cisco.com
username cisco password 0 cisco
ip ssh version 2
line vty 0 4
login local
transport input all
crypto key generate rsa  modulus 2048
Don't forget the last line which is necessary to generate an SSH key.
Let's do the demo
Now, all you need to do is erase all config in ISR and reboot.
ISR891#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
SIR891#reload
System configuration has been modified. Save? [yes/no]:  (no)
Proceed with reload? [confirm]
If everything goes well, device is configured, added to NSO and synced as follows.
admin@ncs# show pnp list
SERIAL       IP ADDRESS  CONFIGURED  ADDED  SYNCED  LAST CONTACT
FGL27131376  10.0.1.131  true        true   true    2017-09-01 02:04:55
admin@ncs# show devices list
NAME    ADDRESS     DESCRIPTION  NED ID     ADMIN STATE
ISR891  10.0.1.131  -            cisco-ios  unlocked
admin@ncs#
7 Comments
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
