Julie Burruss
Community Member
Server Virtualization adoption is growing  rapidly in today’s data centers. Server virtualization enables single  physical server to host multiple virtual machines, allowing cost savings  in terms of fewer  servers bought as well as power and cooling costs.  Server virtualization is no longer limited to lab environments or  certain specific applications. The benefits are clearly established.  With increasing server CPU and memory capacity such as Cisco Unified  Computing System, one can easily fit hundreds of virtual machines on a  single server blade. Server virtualization is widely adopted by all  enterprises for various different types of applications, such as desktop  virtualization, Microsoft Exchange, SQL server etc.
One of the main advantages of server  virtualization is the ability to provide high flexibility to move the  virtual machine (workload) from one physical server to another without  impacting the workload through technologies like virtual machineware ESX  vMotion or Citrix XenSever XenMotion.
Today’s workload mobility is typically  restricted within the same data center from one POD/rack to another  rack. However, the requirements are changing to move the workload beyond  the data center for various reasons to achieve true mobility and  realize the power of server virtualization with no boundaries.
Here are some use cases for long distance  workload mobility:
  • Disaster avoidance: Data centers in the path of  natural calamities (such as hurricanes) needs to proactively migrate the  mission-critical application environment to another data center.
  • Data center migration or consolidation: Applications need to be migrated from one data center to another without  business downtime as part of a data center migration or consolidation  effort.
  • Data center expansion: Virtual machines need to be  migrated to a secondary data center as part of data center expansion to  address power, cooling, and space constraints in the primary data  center.
  • Workload balancing across multiple sites: Virtual  machines need to be migrated between data centers to provide compute  power from data centers closer to the clients (follow the sun) or to  load-balance across multiple sites.
Figure 1: Workload Mobility across Data Centers
In order to achieve virtual machine mobility  across data center, the following infrastructure needs to be  considered:
Layer 2 Connectivity between the physical servers across Data  Centers
The IP address of the virtual machine needs  to remain the same as the virtual machine moves from one server to  another server across the data center. LAN extension is a key  requirement.
Solution:
Cisco Overlay Transport Virtualization protocol (OTV) on the Cisco Nexus  7000. OTV is an industry-first solution that significantly simplifies  extending Layer 2 applications across distributed data centers. You can  now deploy Data Center Interconnect (DCI) between sites without changing  or reconfiguring your existing network design. With OTV you can deploy  virtual computing resources and clusters across  geographically-distributed data centers, delivering transparent workload  mobility, business resiliency, and superior computing resource  efficiencies. OTV does not depend on the type of WAN that you may have  such as dedicated fiber, low-speed/high-speed WAN links or MPLS service  etc as it is purely based on IP connectivity between the sites.
For more information about OTV, please refer  to the following URL: http://www.cisco.com/en/US/prod/switches/ps9441/nexus7000_promo.html
Optimized Outbound/Inbound Traffic to the Workload
Optimized Outbound Traffic  Routing
A primary requirement for application mobility is that the migrated  virtual machine maintains all its existing network connections after it  has been moved to the secondary data center. Traffic routing to and from  the virtual machine needs to be optimized so that any traffic flows in  an optimized way to the virtual machine’s new location.
After the virtual machine has moved to the  new data center, it needs to able to reach its default gateway for  outbound communication. The gateway router is still in the old data  center and hence the traffic will get switched via the DC interconnect  to the old data center. Not really optimal.
Solution:
Cisco OTV allows first hop router localization options. With this  feature, first hop router is local to the site where the virtual machine  is residing. For example, the HSRP virtual IP is shared between both  sites and there is a local HSRP active router with the SAME IP address  on both data centers. When the virtual machine moves to the new data  center, it is still continuing to talk to the same default gateway IP  address, but it will served by the local router. Because they share the  same VLAN, the communication of the HSRP between the sites needs to be  contained —OTV allows you do that. It helps to avoid traffic from being  routed all the way back to the old data center.
Optimized Inbound Traffic Routing
Traffic that is bound for the virtual machine from the external world  needs to be routed to the virtual machine. If the traffic to the virtual  machine originates in the same Layer 2 domain, then the Layer 2  extension between the data centers will suffice. However, if the traffic  to the virtual machine is traversing a Layer 3 network or the Internet,  the traffic will be routed via the old data center.
Solution:
To avoid this triangulation of traffic, advertise more granular routes  from the secondary data center for migrated virtual machines. If these  changes are not provisioned, suboptimal routing may result in additional  delay, which may or may not be acceptable depending on the specific  virtual machine or application. In the future, technologies like Location/ID  Separation Protocol (LISP) will provide IP address portability  between sites so routing to the virtual machine can be done without  needing a lot of routing changes.
Storage Extension between the Data Centers
In order for the mobility to happen live,  the source and the destination ESX server needs to have access to the  shared storage.
Solution:
There are three options for making shared storage available for both the  ESX servers:
  1. Shared storage: Storage remains in the same location as the compute moves to the  secondary data center. In order for the destination ESX to able to reach  the storage, use either IP storage such as NAS or use storage extension  options like Cisco MDS FC and FCIP extension. This method may have some  IO performance implication depending on the distance between the data  centers. The compute IO operations to the storage are performed over the  wide area link.
  2. Active – Passive Storage: Another approach is to move the storage to the same location as the  compute to alleviate IO performance concerns. The storage is active only  in the data center. As the compute is moved from the primary to  secondary data center, one can move the storage via techniques like  Storage vMotion which offers non-disruptive moving of storage while the  workload is active. Depending on the size of storage it may take a  longer time to move the storage to second data center.
  3. Active – Active Storage: In this method, the storage is actively maintained in both data centers  as it is synchronized live between the two. As the compute is moved to  the secondary storage, the ESX server is able to access the local active  storage and hence has no IO performance impact. Active-Active storage  solutions are provided by storage array vendors like EMC vPLEX and  Netapp Metro Clusters. These active-active storage solutions still have  distance limitation to a few hundred miles between data centers.
Summary
Today, technologies exist to seamless  provide mobility between data centers and many deployments have already  happened across the globe. Live mobility involving importing and  exporting to and from the cloud is still not a reality today, but with  advancement in many of these underlying infrastructure technologies,  they are beginning to take shape.
