Abey K. George
Document Objective
This document discuss a common issue observed during the workload migration to ACI fabric.
Problem Description
VMware Virtual machines are hosted in Cisco UCS-B series blade servers (ESXi servers). UCS Fabric interconnect is connected to leaf101 & leaf102 (vPC - LACP active).
EPG "abegeorg:webinar:games" has a static-binding with vPC port (FI-A and FI-B) for trunk vlan-3799.
Once the VM workload is migrated to new server blades connected to ACI fabric (DVS is managed to vCenter), the intermittent connectivity issue is observed with the newly migrated VM. Users are experiencing the slowness in accessing the services, sometimes services are not accessible.
The example VM considered for this troubleshooting is IP -> 10.10.79.1/24, the default GW of this endpoint is residing in ACI fabric (10.10.79.254/24)
Common troubleshooting steps
This sections covers common troubleshooting steps can be used to isolate similar issues. You are encouraged to use these steps to troubleshoot such connectivity issues.
Validating the connectivity
Now, lets check some connectivity state and validate how the ACI fabric is connected to the server (in this case UCS B-Series chassis). The CDP and port-channel output obtained below indicates that the FI-A & FI-B are connected to ACI fabric leaf (leaf101 & leaf102) using vPC. The vPC ports and up.
leaf101# show cdp neighbors
<< snip >>
UCS-ACI-PODs-A(SSI182207R7) Eth1/37 171 S I s UCS-FI-6248UP Eth1/5
UCS-ACI-PODs-B(SSI1822054V) Eth1/38 127 S I s UCS-FI-6248UP Eth1/5
<< snip >>
leaf101#
leaf101# show vpc extended
<< snip >>
691  Po3    up     success     success              3799,3874-3875,3887  abegeorg-ucs-a-vpc
692  Po9    up     success     success              3799,3874-3875,3887 abegeorg-ucs-b-vpc
<< snip >>
leaf101#
leaf101# show port-channel extended
<< snip >>
3     Po3(SU)     abegeorg-ucs-a-vpc       LACP      Eth1/37(P)
9     Po9(SU)     abegeorg-ucs-b-vpc       LACP      Eth1/38(P)
10 Po10(SU) abegeorg-ucs-b-vpc LACP Eth1/38(P)
leaf101#
leaf102# show cdp neighbors
<< snip >>
UCS-ACI-PODs-A(SSI182207R7) Eth1/37 165 S I s UCS-FI-6248UP Eth1/6
UCS-ACI-PODs-B(SSI1822054V) Eth1/38 121 S I s UCS-FI-6248UP Eth1/6
<< snip >>
leaf102#
leaf102# show vpc extended
<< snip >>
692  Po2    up     success     success              3799,3874-3875,3887 abegeorg-ucs-b-vpc
<< snip >>
leaf102#
leaf102# show port-channel extended
<< snip >>
2     Po2(SU)     abegeorg-ucs-b-vpc       LACP      Eth1/38(P)
leaf102#
In this case, the default GW of the VM workload is at the ACI fabric. So,  lets do some connectivity test from ACI fabric. The iping result indicates that there are intermittent ping drops, the connectivity from the ACI fabric itself is having issue.
iPing test
leaf101# iping -V abegeorg:webinar 10.10.79.1
PING 10.10.79.1 (10.10.79.1) from 10.10.79.254: 56 data bytes
Request 0 timed out
Request 1 timed out
64 bytes from 10.10.79.1: icmp_seq=2 ttl=64 time=0.398 ms
64 bytes from 10.10.79.1: icmp_seq=3 ttl=64 time=0.436 ms
64 bytes from 10.10.79.1: icmp_seq=4 ttl=64 time=0.405 ms
--- 10.10.79.1 ping statistics ---
5 packets transmitted, 3 packets received, 40.00% packet loss
round-trip min/avg/max = 0.398/0.413/0.436 ms
leaf101#
leaf102# iping -V abegeorg:webinar 10.10.79.1
64 bytes from 10.10.79.1: icmp_seq=0 ttl=64 time=0.622 ms
Request 1 timed out
64 bytes from 10.10.79.1: icmp_seq=2 ttl=64 time=0.601 ms
Request 3 timed out
64 bytes from 10.10.79.1: icmp_seq=4 ttl=64 time=0.662 ms
round-trip min/avg/max = 0.601/0.628/0.662 ms
leaf102#
Verify Endpoint learning
Now, lets check the endpoint learning details...  using "show system internal epm endpoint ip 10.10.79.1" . When I validated the fabric-encap (VLAN vnid) for the encap vlan-3799 in both leaf switch, we see it different. It should be ideally same VLAN vnid across across the fabric. In this case, we see this different across the vPC pair leaf, which causes the connectivity issue.
>>> @leaf101
leaf101# show system internal epm endpoint ip 10.10.79.1
MAC : 0050.5690.a99e ::: Num IPs : 1
IP# 0 : 10.10.79.1 ::: IP# 0 flags :
Vlan id : 34 ::: Vlan vnid : 13392 ::: VRF name : abegeorg:webinar
BD vnid : 15597462 ::: VRF vnid : 2129922
Phy If : 0x16000002 ::: Tunnel If : 0
Interface : port-channel3
Flags : 0x80004c05 ::: sclass : 10941 ::: Ref count : 5
EP Create Timestamp : 04/08/2018 19:38:36.866026
EP Update Timestamp : 04/08/2018 19:38:36.866026
EP Flags : local|vPC|IP|MAC|sclass|timer|
leaf101# show vlan id 34 extended
VLAN Name Status Ports
34 abegeorg:webinar:games active Eth1/37, Eth1/38, Po3, Po9
VLAN Type Vlan-mode Encap
34 enet CE vlan-3799
leaf101#
leaf101# vsh_lc
vsh_lc
module-1#
module-1# show system internal eltmc info vlan brief | egrep "Fabric_enc|3799"
VlanId HW_VlanId Type Access_enc Access_enc Fabric_enc Fabric_enc BDVlan
34 41 FD_VLAN 802.1q 3799 VXLAN 13392 33
module-1#
>>> @leaf102
leaf102# show system internal epm endpoint ip 10.10.79.1
Vlan id : 50 ::: Vlan vnid : 13300 ::: VRF name : abegeorg:webinar
EP Create Timestamp : 04/08/2018 19:38:46.927238
EP Update Timestamp : 04/08/2018 19:38:56.875307
leaf102#
leaf102# show vlan id 50 extended
50 abegeorg:webinar:games active Eth1/37, Eth1/38, Po2, Po3
50 enet CE vlan-3799
leaf102#
leaf102# vsh_lc
vsh_lc
50 35 FD_VLAN 802.1q 3799 VXLAN 13300 49
module-1#
Reviewing EPM trace for endpoint learning across vPC leaf peer
The EPM-trace indicates that the leaf101 is receiving an endpoint update from its vPC peer (leaf102) but the received EPG vnid 13300 is doesn't exist on this leaf101. Hence, the EPM removes the endpoint from its database. Similarly,  leaf102 is receiving an endpoint update from its vPC peer (leaf101) but the received EPG vnid 13192 is doesn't exist on this leaf102. Hence, the EPM removes the endpoint from its database.
>>>/var/log/dme/log/epm-trace.txt @ leaf101
[2018 Apr 8 19:25:53.653200154:1119:epm_debug_dump_epm_ep_req:359:t] log_collect_ep_event
req_src=EPM_SAP_PEER
optype = ADD; mac = 0050.5690.a99e; num_ips = 1
ip[0] = 10.10.79.1
vlan = 3799; epg_vnid = 13300; bd_vnid = 15597462; vrf_vnid = 2129922
ifindex = 0x7e0002b3; tep_ip_tun_ifindex = 0; sclass = 10941
flags = local|vPC|IP|MAC|sclass|
ep_req_ts = 04/08/2018 19:25:39.030373
[2018 Apr 8 19:25:53.653216494:1124:epm_mcec_pre_process_ep_req:808:E] Unknown FD vlan/vxlan 13300 bd_vnid 15597462 ... ignoring EP req; ep_flags local|vPC|IP|MAC|sclass|
[2018 Apr 8 19:25:53.653218130:1125:epm_send_ep_del_ack_to_peer:1204:t] EP req for EP for which FD/BD/VRF/Tun doesn't exist, deleting EP from EP Db, if it exists
[2018 Apr 8 19:25:53.653221839:1126:epm_pre_process_ep_req:4097:E] Failed to pre-process EP req, err : VLAN does not exist
[2018 Apr 8 19:25:53.653224190:1127:epm_process_ep_req:4464:E] EP req pre processing failed, err : VLAN does not exist
[2018 Apr 8 19:25:53.653225512:1128:epm_mcec_ep_req_handler:459:E] Error processing EP# 1 in EP request from peer EPM
[2018 Apr 8 19:25:53.653229434:1129:epm_debug_dump_epm_ep_req:359:t] log_collect_ep_event
optype = ADD; mac = 0050.5690.233a; num_ips = 1
ip[0] = 10.10.79.2
ep_req_ts = 04/08/2018 19:25:29.986185
[2018 Apr 8 19:25:53.653244299:1134:epm_mcec_pre_process_ep_req:808:E] Unknown FD vlan/vxlan 13300 bd_vnid 15597462 ... ignoring EP req; ep_flags local|vPC|IP|MAC|sclass|
[2018 Apr 8 19:25:53.653245934:1135:epm_send_ep_del_ack_to_peer:1204:t] EP req for EP for which FD/BD/VRF/Tun doesn't exist, deleting EP from EP Db, if it exists
[2018 Apr 8 19:25:53.653249397:1136:epm_pre_process_ep_req:4097:E] Failed to pre-process EP req, err : VLAN does not exist
[2018 Apr 8 19:25:53.653251663:1137:epm_process_ep_req:4464:E] EP req pre processing failed, err : VLAN does not exist
[2018 Apr 8 19:25:53.653253034:1138:epm_mcec_ep_req_handler:459:E] Error processing EP# 2 in EP request from peer EPM
>>> /var/log/dme/log/epm-trace.txt @ leaf102
[2018 Apr 8 17:27:36.566066818:1021641:epm_debug_dump_epm_ep_req:359:t] log_collect_ep_event
ip[0] = 10.10.79.1
vlan = 3799; epg_vnid = 13192; bd_vnid = 16646020; vrf_vnid = 2129922
ifindex = 0x7e0002b3; tep_ip_tun_ifindex = 0; sclass = 32772
ep_req_ts = 04/08/2018 17:27:39.330522
[2018 Apr 8 17:27:36.566087404:1021646:epm_mcec_pre_process_ep_req:808:E] Unknown FD vlan/vxlan 13192 bd_vnid 16646020 ... ignoring EP req; ep_flags local|vPC|IP|MAC|sclass|
[2018 Apr 8 17:27:36.566089169:1021647:epm_send_ep_del_ack_to_peer:1204:t] EP req for EP for which FD/BD/VRF/Tun doesn't exist, deleting EP from EP Db, if it exists
[2018 Apr 8 17:27:36.566091529:1021648:epm_process_ep_del:2313:t] Delete req rcvd for EP:
[2018 Apr 8 17:27:36.566093844:1021649:epm_debug_dump_epm_ep:398:t] log_collect_ep_event
EP entry:
ip[0] = 10.10.79.1
vlan = 34; epg_vnid = 13300; bd_vnid = 16646020; vrf_vnid = 2129922
ifindex = 0x16000002; tun_ifindex = 0; vtep_tun_ifindex = 0
sclass = 32772; ref_cnt = 5
flags = local|vPC|IP|MAC|sclass|timer|
create_ts = 04/08/2018 17:27:38.827157
upd_ts = 04/08/2018 17:27:39.321509
[2018 Apr 8 17:27:36.566114551:1021655:epm_ep_notify_coop:1465:t] rec_ts: 1523179659:332728768
[2018 Apr 8 17:27:36.566118069:1021656:epm_process_ep_del:2401:t] Deleting EP from the DB
[2018 Apr 8 17:27:36.566233949:1021657:epm_add_del_epg_dyn_pol_obj:2429:t] Del dyn pol trig obj with DN sys/ctx-[vxlan-2129922]/bd-[vxlan-16646020]/vlan-[vlan-3799]/dynepgpolicytrig, vlan id 34 bd = 16646020; mac = 0050.5690.a99e Active EP count on if 0x16000002 is 1
[2018 Apr 8 17:27:36.566244842:1021660:epm_del_ip_ep_objs:2176:t] Deleting IP EP obj of (vrf 2129922, IP 10.10.79.1)
[2018 Apr 8 17:27:36.566265002:1021661:epm_del_mac_ep_obj:2200:t] Deleting MacEp object of (BD 16646020, MAC 0050.5690.a99e) vlan_id 34
[2018 Apr 8 17:27:36.566268373:1021662:epm_attach_to_dirty_vlan_list:4359:t] Adding vlan 34 to dirty list with version 17382
[2018 Apr 8 17:27:36.566281362:1021663:epm_pre_process_ep_req:4097:E] Failed to pre-process EP req, err : VLAN does not exist
[2018 Apr 8 17:27:36.566283518:1021664:epm_process_ep_req:4464:E] EP req pre processing failed, err : VLAN does not exist
Understanding  EPG vnid in ACI fabric
Now, let's understand how the EPG vnid is derived in ACI fabric. The formula for deriving the EPG-vnid is to add the position of encap (starting at 0) within the VLAN block to the base value.
On leaf101, the EPG-vnid is 13392, was pulled from a the following VLAN block which is associated with physical domain abegeorg-esxi3-phyDom. The EPG-vnid is derived in the following manner.
base : 13392
block : vlan-3799 to vlan-3810. Hence,index for vlan-3799 (starting 0): 0
EPG-vnid: 13392 + 0 = 13392
# stp.AllocEncapBlkDef
encapBlk : uni/infra/vlanns-[abegeorg-vlan-esxi3-static]-static/from-[vlan-3799]-to-[vlan-3810]
base : 13392
childAction :
descr :
dn : allocencap-[uni/infra]/encapnsdef-[uni/infra/vlanns-[abegeorg-vlan-esxi3-static]-static]/allocencapblkdef-[uni/infra/vlanns-[abegeorg-vlan-esxi3
-static]-static/from-[vlan-3799]-to-[vlan-3810]]
lcOwn : resolveOnBehalf
modTs : 2018-04-08T19:25:48.615+08:00
monPolDn : uni/fabric/monfab-default
name :
nameAlias :
ownerKey :
ownerTag :
rn : allocencapblkdef-[uni/infra/vlanns-[abegeorg-vlan-esxi3-static]-static/from-[vlan-3799]-to-[vlan-3810]]
status :
to : vlan-3810
On leaf102, the EPG-vnid is 13300, was pulled from a the following VLAN block which is associated with physical domain abegeorg-esxi2-phyDom. The EPG-vnid is derived in the following manner.
base : 13292
block : vlan-3791 to vlan-3799. Hence,index for vlan-3799 (starting 0): 8
EPG-vnid: 13292 + 8 = 13300
encapBlk : uni/infra/vlanns-[abegeorg-vlan-esxi2-static]-static/from-[vlan-3791]-to-[vlan-3799]
base : 13292
childAction :
descr :
dn : allocencap-[uni/infra]/encapnsdef-[uni/infra/vlanns-[abegeorg-vlan-esxi2-static]-static]/allocencapblkdef-[uni/infra/vlanns-[abegeorg-vlan-esxi2-static]-static/from-[vlan-3791]-to-[vlan-3799]]
name :
nameAlias :
ownerKey :
ownerTag :
rn : allocencapblkdef-[uni/infra/vlanns-[abegeorg-vlan-esxi2-static]-static/from-[vlan-3791]-to-[vlan-3799]]
status :
to : vlan-3799
The EPG-vnid mismatch occured due to the overlapping VLAN pool.
Review the Physical domain association and VLAN pools
There are two physical domains are associated with this EPG (abegeorg-esxi2-phyDom & abegeorg-esxi3-phyDom)
Let's review these domains and its associated VLAN pool.
The domain abegeorg-esxi2-phyDom uses vlan pool abegeorg-vlan-esxi2-static (vlan-3791 to vlan-3799)
The domain abegeorg-esxi3-phyDom uses vlan pool abegeorg-vlan-esxi3-static (vlan-3799 to vlan-3810)
Screen Shot 2018-04-08 at 9.47.04 PM.pngScreen Shot 2018-04-08 at 9.47.38 PM.png
Resolution
Manually resolve the VLAN overlap. Please note that this is a disruptive operation and cause traffic drops. In this example, the abegeorg-esxi3-phyDom was redundant, so I removed it. Please review your requirement and make the changes accordingly.
Verification
Now, let's verify how the EPG-vnid is derived. We can see that the EPG-vnid derived at both leaf101 & leaf102 are same, which is 13300.
Vlan id : 34 ::: Vlan vnid : 13300 ::: VRF name : abegeorg:webinar
EP Create Timestamp : 04/08/2018 19:48:09.626467
EP Update Timestamp : 04/08/2018 19:51:56.597519
leaf101#
leaf101# vsh_lc
vsh_lc
module-1#
34 41 FD_VLAN 802.1q 3799 VXLAN 13300 33
module-1#
EP Update Timestamp : 04/08/2018 19:54:22.823590
leaf102#
leaf102# vsh_lc
vsh_lc
module-1#
This restores the connectivity to stable state...
andre.godoy
Hey Abey,
Awesome post,
Can you give a tip? We are doing a migration to ACI, but when the legacy network send a TCN to ACI, the ACI made a Flush on mac table....thats a normal behavior, but in my case after the flush , the ACI delay 1 min to relearn the endpoints.
I saw on epm_trace something like:
EP entry:
mac = 00f2.8b2b.7d40; num_ips = 0
vlan = 100; epg_vnid = 13893; bd_vnid = 15237055; vrf_vnid = 2260992
ifindex = 0x16000007; tun_ifindex = 0; vtep_tun_ifindex = 0
sclass = 16417; ref_cnt = 4
flags = local|vPC|MAC|sclass|timer|
create_ts = 09/19/2018 21:37:09.484093
upd_ts = 09/19/2018 21:40:20.890612
[2018 Sep 20 04:42:55.057799486:1969235488:epm_ep_notify_coop:1465:t] rec_ts: 1537404094:885295281
[2018 Sep 20 04:42:55.057801333:1969235489:epm_process_ep_del:2401:t] Deleting EP from the DB
bd = 15237055; mac = 00f2.8b2b.7d40 Active EP count on if 0x16000007 is 0
[2018 Sep 20 04:42:55.057809697:1969235492:epm_del_mac_ep_obj:2182:t] Deleting MacEp object of (BD 15237055, MAC 00f2.8b2b.7d40)
vlan_id 100[2018 Sep 20 04:42:55.057816026:1969235493:epm_attach_to_dirty_vlan_list:4326:t] Adding vlan 100 to dirty list with version 6598
[2018 Sep 20 04:42:55.057817606:1969235494:epm_attach_to_dirty_vlan_list:4340:t] vlan 100 is already in dirty list with ver 6598
[2018 Sep 20 04:42:55.057819622:1969235495:epm_process_ep_del:2313:t] Delete req rcvd for EP:
[2018 Sep 20 04:42:55.057823264:1969235496:epm_debug_dump_epm_ep:398:t] log_collect_ep_event
Another thing,  1 sec later I see this messages "Endpoint request rejected as learning is disabled"
[2018 Sep 20 04:42:56.022112353:1969258109:epm_mcec_pre_process_ep_req:772:t] Don't learn flag set, ignoring EP req
[2018 Sep 20 04:42:56.022114100:1969258110:epm_pre_process_ep_req:4064:E] Failed to pre-process EP req, err : Endpoint request rejected as learning is disabled
[2018 Sep 20 04:42:56.022115620:1969258111:epm_process_ep_req:4431:E] EP req pre processing failed, err : Endpoint request rejected as learning is disabled
[2018 Sep 20 04:42:56.022116678:1969258112:epm_mcec_ep_req_handler:459:E] Error processing EP# 10 in EP request from peer EPM
[2018 Sep 20 04:42:56.022118793:1969258113:epm_debug_dump_epm_ep_req:359:t] log_collect_ep_event
optype = ADD; mac = 00f2.8b2b.7d40; num_ips = 0
vlan = 262; epg_vnid = 13893; bd_vnid = 15237055; vrf_vnid = 2260992
ifindex = 0x7e000002; tep_ip_tun_ifindex = 0; sclass = 16417
ep_req_ts = 09/19/2018 21:41:35.831981
[2018 Sep 20 04:42:56.022123851:1969258116:epm_mcec_pre_process_ep_req:772:t] Don't learn flag set, ignoring EP req
[2018 Sep 20 04:42:56.022125662:1969258117:epm_pre_process_ep_req:4064:E] Failed to pre-process EP req, err : Endpoint request rejected as learning is disabled
[2018 Sep 20 04:42:56.022127164:1969258118:epm_process_ep_req:4431:E] EP req pre processing failed, err : Endpoint request rejected as learning is disabled
[2018 Sep 20 04:42:56.022128211:1969258119:epm_mcec_ep_req_handler:459:E] Error processing EP# 11 in EP request from peer EPM
[2018 Sep 20 04:42:56.022130311:1969258120:epm_debug_dump_epm_ep_req:359:t] log_collect_ep_event
Do you already see something like this?
Thank you!
