This document provides the configuration example for deploying OTV in the Data Centers having multiple VRFs.
Topology
There are two Aggregation VDCs in each data center having three VRFs Web, App and DB. Both the Data Centers are connected via two 10 Gig circuits connected directly to the Aggregation Layer switches.
Configuration
Main purpose of this document is to show OTV related configuration both at the OTV VDC and at the Aggregation VDCs.
There are three vlans 701, 750 and 775 are extended between the two Data Centers through OTV. These VLANs have SVIs at the aggregation layer corresponds to the three different VRFs.
OTV join interface in the OTV VDC is configured in the default VRF.
OTV join interface in the Aggregation VDC is configured in the App VRF. The choice of VRF is depends on the customer network.
The Layer 3 VRFs are extended between the two Data Centers and OSPF is the IGP protocol.
OTV Adjacency Server Unicast is used in this configuration example.
Data Center 1 - Aggregation - 1
hostname DC1-N7K-AGG-01
vrf context web
vrf context app
vrf context db
vrf context vpckeepalive
vlan 900
  name native-vlan
vlan 453
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
interface port-channel3
  description vPC Peer Keep Alive
  vrf member vpckeepalive
  no ip redirects
  ip address 192.168.1.1/30
interface Ethernet1/1
  channel-group 3 mode active
  no shutdown
interface Ethernet2/1
  no shutdown
vpc domain 11
  peer-switch
  role priority 10
  system-priority 4096
  peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf vpckeepalive
  peer-gateway
  auto-recovery
  ip arp synchronize
interface port-channel2
  description vPC Peer Link
  switchport
  switchport mode trunk
  switchport trunk native vlan 900
  spanning-tree port type network
  vpc peer-link
interface Ethernet3/1
  switchport
  rate-mode dedicated force
  channel-group 2 mode active
  no shutdown
interface Ethernet4/1
  switchport
  no shutdown
interface port-channel13
  description OTV Internal Interface – OTV-VDC-1
  switchport
  vpc 13
interface Ethernet7/25
  switchport
  channel-group 13 mode active
  no shutdown
interface port-channel14
  description OTV Internal Interface – OTV-VDC-2
  switchport
  vpc 14
interface Ethernet8/25
  switchport
  channel-group 14 mode active
  no shutdown
interface Vlan701
  no shutdown
  description Web VLAN
  vrf member web
  no ip redirects
  ip address 10.16.1.2/24
  ip router ospf 100 area 0.0.0.0
  hsrp version 2
  hsrp 701
    preempt
    priority 200
    ip 10.16.1.1
interface Vlan750
  no shutdown
  description App VLAN
  vrf member app
  no ip redirects
  ip address 10.17.1.2/24
  hsrp version 2
  hsrp 750
    preempt
    priority 200
    ip 10.17.1.1
interface Vlan775
  no shutdown
  description DB VLAN
  vrf member db
  no ip redirects
  ip address 10.18.1.2/24
  hsrp version 2
  hsrp 775
    preempt
    priority 200
    ip 10.18.1.1
interface port-channel12
  description OTV Join Interface – OTV-VDC-1
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.3.0.49/30
interface Ethernet8/18
  mtu 9216
  channel-group 12 mode active
  no shutdown
interface Ethernet9/18
  mtu 9216
  no shutdown
interface Ethernet3/17
  description To Data-Center-2 Aggregation-1 VDC
  mtu 9216
  no shutdown
interface Ethernet3/17.725
  encapsulation dot1q 725
  vrf member web
  ip address 10.16.0.13/30
  ip ospf network point-to-point
  no ip ospf passive-interface
  no shutdown
interface Ethernet3/17.750
  mtu 9216
  encapsulation dot1q 750
  vrf member app
  ip address 10.17.0.13/30
  no shutdown
interface Ethernet3/17.775
  encapsulation dot1q 775
  vrf member db
  ip address 10.18.0.13/30
  no shutdown
  description Layer 3 Between Nexus 7ks
  mtu 9216
  no shutdown
interface port-channel1.725
  vrf member web
  no ip redirects
  ip address 10.16.0.9/30
  no shutdown
interface port-channel1.750
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.17.0.9/30
  no shutdown
interface port-channel1.775
  vrf member db
  no ip redirects
  ip address 10.18.0.9/30
  no shutdown
interface Ethernet3/25
  mtu 9216
  channel-group 1 mode active
  no shutdown
interface Ethernet4/25
  mtu 9216
  no shutdown
interface loopback1
  description web-loopback
  vrf member web
  ip address 10.16.0.254/32
interface loopback2
  description app-loopback
  vrf member app
  ip address 10.17.0.254/32
interface loopback3
  description db-loopback
  vrf member db
  ip address 10.18.0.254/32
router ospf 100
  vrf web
    router-id 10.16.0.254
    passive-interface default
  vrf app
    router-id 10.17.0.254
  vrf db
    router-id 10.18.0.254
Data Center 1 - Aggregation - 2
hostname DC1-N7K-AGG-02
vrf context web
vrf context app
vrf context db
vlan 900
  name native-vlan
vlan 453
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  no ip redirects
  ip address 192.168.1.2/30
  no shutdown
  no shutdown
vpc domain 11
  peer-switch
  role priority 100
  peer-keepalive destination 192.168.1.1 source 192.168.1.2 vrf vpckeepalive
  peer-gateway
  auto-recovery
  ip arp synchronize
  switchport
  vpc peer-link
  switchport
  no shutdown
  switchport
  no shutdown
  switchport
  vpc 13
  switchport
  no shutdown
  switchport
  vpc 14
  switchport
no shutdown
interface Vlan701
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.16.1.3/24
  hsrp version 2
  hsrp 701
    ip 10.16.1.1
interface Vlan750
  no shutdown
  vrf member app
  no ip redirects
  ip address 10.17.1.3/24
  hsrp version 2
  hsrp 750
    ip 10.17.1.1
interface Vlan775
  no shutdown
  description DB VLAN
  vrf member db
  no ip redirects
  ip address 10.18.1.3/24
  hsrp version 2
  hsrp 775
    ip 10.18.1.1
  description OTV Join Interface – OTV-VDC-2
  mtu 9216
  vrf member trusted
  no ip redirects
  ip address 10.3.0.53/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
  description To Data-Center-2 Aggregation-2 VDC
  mtu 9216
  no shutdown
  vrf member web
  ip address 10.16.0.17/30
  no shutdown
  mtu 9216
  vrf member app
  ip address 10.17.0.17/30
  no shutdown
  vrf member db
  ip address 10.18.0.17/30
  no shutdown
  mtu 9216
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.16.0.10/30
  no shutdown
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.17.0.10/30
  no shutdown
  vrf member db
  no ip redirects
  ip address 10.18.0.10/30
  no shutdown
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
interface loopback1
  vrf member web
  ip address 10.16.0.253/32
interface loopback2
  vrf member app
  ip address 10.17.0.253/32
interface loopback3
  vrf member db
  ip address 10.18.0.253/32
router ospf 100
  vrf web
     router-id 10.16.0.253
  vrf app
    router-id 10.17.0.253
  vrf db
    router-id 10.18.0.253
Data Center 1 - OTV - 1
hostname DC1-N7K-OTV-01
feature otv
feature lacp
vlan 900
  name native-vlan
vlan 453
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  description Join Interface L3
  mtu 9216
  no ip redirects
  ip address 10.3.0.50/30
interface Ethernet8/26
  mtu 9216
  no shutdown
interface Ethernet9/26
  mtu 9216
  no shutdown
ip route 0.0.0.0/0 10.3.0.49
otv site-identifier 0x1
otv site-vlan 453
interface Overlay100
  description OTV Data-Center-1
  otv join-interface port-channel12
  otv extend-vlan 701, 750, 775
  otv use-adjacency-server 10.3.0.50 10.35.0.50 unicast-only
  otv adjacency-server unicast-only
  no shutdown
  description Internal Interface L2 Port-Channel
  switchport
  switchport
  no shutdown
interface Ethernet9/25
  switchport
  no shutdown
ip access-list ALL_IPs
  10 permit ip any any
mac access-list ALL_MACs
  10 permit any any
ip access-list HSRP_IP
  10 permit udp any 224.0.0.2/32 eq 1985
  20 permit udp any 224.0.0.102/32 eq 1985
mac access-list HSRP_VMAC
  10 permit 0000.0c07.ac00 0000.0000.00ff any
  20 permit 0000.0c9f.f000 0000.0000.0fff any
arp access-list HSRP_VMAC_ARP
  10 deny ip any mac 0000.0c07.ac00 ffff.ffff.ff00
  20 deny ip any mac 0000.0c9f.f000 ffff.ffff.f000
  30 permit ip any mac any
vlan access-map HSRP_Localization 10
       match mac address HSRP_VMAC
       match ip address HSRP_IP
       action drop
vlan access-map HSRP_Localization 20
       match mac address ALL_MACs
       match ip address ALL_IPs
       action forward
vlan filter HSRP_Localization vlan-list 2-452,454-800,1151-1200
ip arp inspection filter HSRP_VMAC_ARP vlan 701,750,775
mac-list OTV_HSRP_VMAC_deny seq 10 deny 0000.0c07.ac00 ffff.ffff.ff00
mac-list OTV_HSRP_VMAC_deny seq 11 deny 0000.0c9f.f000 ffff.ffff.f000
mac-list OTV_HSRP_VMAC_deny seq 20 permit 0000.0000.0000 0000.0000.0000
route-map OTV_HSRP_filter permit 10
  match mac-list OTV_HSRP_VMAC_deny
otv-isis default
  vpn Overlay100
    redistribute filter route-map OTV_HSRP_filter
Data Center 1 - OTV - 2
hostname DC1-N7K-OTV-02
feature otv
feature lacp
vlan 900
  name native-vlan
vlan 453
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  mtu 9216
  no ip redirects
  ip address 10.3.0.54/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
ip route 0.0.0.0/0 10.3.0.53
otv site-vlan 453
  no shutdown
  switchport
  switchport
  no shutdown
  switchport
  no shutdown
  10 permit any any
       action drop
       action forward
otv-isis default
  vpn Overlay100
Data Center 2 - Aggregation - 1
hostname DC2-N7K-AGG-01
vrf context web
vrf context app
vrf context db
vlan 1900
  name native-vlan
vlan 1600
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  no ip redirects
  ip address 192.168.2.1/30
  no shutdown
  no shutdown
vpc domain 12
  peer-switch
  role priority 10
  peer-keepalive destination 192.168.2.2 source 192.168.2.1 vrf vpckeepalive
  peer-gateway
  auto-recovery
  ip arp synchronize
  switchport
  switchport trunk native vlan 1900
  vpc peer-link
  switchport
  no shutdown
  switchport
  no shutdown
  switchport
  vpc 13
  switchport
  no shutdown
  switchport
  vpc 14
  switchport
  no shutdown
interface Vlan701
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.16.1.4/24
  hsrp version 2
  hsrp 701
    preempt
    priority 200
    ip 10.16.1.1
interface Vlan750
  no shutdown
  vrf member app
  no ip redirects
  ip address 10.17.1.4/24
  hsrp version 2
  hsrp 750
    preempt
    priority 200
    ip 10.17.1.1
interface Vlan775
  no shutdown
  description DB VLAN
  vrf member db
  no ip redirects
  ip address 10.18.1.4/24
  hsrp version 2
  hsrp 775
    preempt
    priority 200
    ip 10.18.1.1
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.35.0.49/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
  description To Data-Center-1 Aggregation-1 VDC
  mtu 9216
  no shutdown
  vrf member web
  ip address 10.16.0.14/30
  no shutdown
  mtu 9216
  vrf member app
  ip address 10.17.0.14/30
  no shutdown
  vrf member db
  ip address 10.18.0.14/30
  no shutdown
  mtu 9216
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.26.0.9/30
  no shutdown
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.27.0.9/30
  no shutdown
  vrf member db
  no ip redirects
  ip address 10.28.0.9/30
  no shutdown
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
interface loopback1
  vrf member web
  ip address 10.26.0.254/32
interface loopback2
  vrf member app
  ip address 10.27.0.254/32
interface loopback3
  vrf member db
  ip address 10.28.0.254/32
router ospf 100
  vrf web
    router-id 10.26.0.254
  vrf app
    router-id 10.27.0.254
  vrf db
    router-id 10.28.0.254
Data Center 2 - Aggregation - 2
hostname DC2-N7K-AGG-02
vrf context web
vrf context app
vrf context db
vlan 1900
  name native-vlan
vlan 1600
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  no ip redirects
  ip address 192.168.2.2/30
  no shutdown
  no shutdown
vpc domain 12
  peer-switch
  role priority 100
  peer-keepalive destination 192.168.2.1 source 192.168.2.2 vrf vpckeepalive
  peer-gateway
  auto-recovery
  ip arp synchronize
  switchport
  vpc peer-link
  switchport
  no shutdown
  switchport
  no shutdown
  switchport
  vpc 13
  switchport
  no shutdown
  switchport
  vpc 14
  switchport
  no shutdown
interface Vlan701
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.16.1.5/24
  hsrp version 2
  hsrp 701
    ip 10.16.1.1
interface Vlan750
  no shutdown
  vrf member app
  no ip redirects
  ip address 10.17.1.5/24
  hsrp version 2
  hsrp 750
    ip 10.17.1.1
interface Vlan775
  no shutdown
  description DB VLAN
  vrf member db
  no ip redirects
  ip address 10.18.1.5/24
  hsrp version 2
  hsrp 775
    ip 10.18.1.1
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.35.0.53/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
  description To Data-Center-1 Aggregation-2 VDC
  mtu 9216
  no shutdown
  vrf member web
  ip address 10.16.0.18/30
  no shutdown
  mtu 9216
  vrf member app
  ip address 10.17.0.18/30
  no shutdown
  vrf member db
  ip address 10.18.0.18/30
  no shutdown
  mtu 9216
  no shutdown
  vrf member web
  no ip redirects
  ip address 10.26.0.10/30
  no shutdown
  mtu 9216
  vrf member app
  no ip redirects
  ip address 10.27.0.10/30
  no shutdown
  vrf member db
  no ip redirects
  ip address 10.28.0.10/30
  no shutdown
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
interface loopback1
  vrf member web
  ip address 10.26.0.253/32
interface loopback2
  vrf member app
  ip address 10.27.0.253/32
interface loopback3
  vrf member db
  ip address 10.28.0.253/32
router ospf 100
  vrf web
    router-id 10.26.0.253
  vrf app
    router-id 10.27.0.253
  vrf db
    router-id 10.28.0.253
Data Center 2 - OTV - 1
hostname DC2-N7K-OTV-01
feature otv
feature lacp
vlan 1900
  name native-vlan
vlan 1600
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  mtu 9216
  no ip redirects
  ip address 10.35.0.50/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
ip route 0.0.0.0/0 10.35.0.49
otv site-identifier 0x2
otv site-vlan 1600
  description OTV Data-Center-2
  no shutdown
  switchport
  switchport
  no shutdown
  switchport
  no shutdown
  10 permit any any
       action drop
       action forward
otv-isis default
  vpn Overlay100
Data Center 2 - OTV - 2
hostname DC2-N7K-OTV-02
feature otv
feature lacp
vlan 1900
  name native-vlan
vlan 1600
  name otv-site-vlan
vlan 701
  name web
vlan 750
  name app
vlan 775
  name db
  mtu 9216
  no ip redirects
  ip address 10.35.0.54/30
  mtu 9216
  no shutdown
  mtu 9216
  no shutdown
ip route 0.0.0.0/0 10.35.0.53
otv site-vlan 1600
  no shutdown
  switchport
  switchport
  no shutdown
  switchport
  no shutdown
  10 permit any any
       action drop
       action forward
otv-isis default
  vpn Overlay100
