BUM loop in VXLAN multisite CML
exness-noc
We have vxlan multisite topology in CML. When we create l2vni between site and start ping from client in site 1 to client in site 2 we get 100% CPU LOAD on BGW because on arp loop.
APR request goes from the 1st site bgw  to the 2nd site bgw, then the same ARP request + 14 bytes goes from the 2nd site bgw towards the 1st bgw, then APR request goes from the 1st site bgw  to the 2nd site bgw plus another 14 bytes, etc. The frame increases in size each time and at some point begins to fragment. Is this expected behavior for a virtual nexus 9k in the role of spine + bgw?
16 Replies 16
 Can I see config of spine and leaf
MHM
Configuration of the BGW, which is shown in the picture CML_1.jpg on the right is in the attachment.  The configuration of the BGW of the 2nd site differs only in the ASN.
I also noticed the following, that when the BGW receives an ARP request from the leaf (fabric-Link), when forwarding this packet to the DCI, it changes the original ARP packet (adds a 14-byte to trailer field in ethernet frame).
I repeated the topology in EVE-NG and got the same result. I don't understand, is this some kind of limitation of the multi-site topology in a virtual environment or I don't conceptually understand why this happens.
Are you sure there is no conflict in vtep LO IP between two sites?
MHM
exness-noc
Yes.
ams-bgw-1# sh nve peers
Interface Peer-IP State LearnType Uptime Router-Mac
nve1 10.250.137.2 Up CP 00:00:47 5201.c528.1b08  -- PIP_VTEP BGW 2nd site
nve1 10.250.137.129 Up CP 00:00:17 0200.0afa.8981 -- VIP_VTEP BGW 2nd site
ld-bgw-2# sh nve peers
nve1 10.250.129.1 Up CP 00:00:49 5217.1a98.1b08    -- PIP_VTEP BGW 1st site
nve1 10.250.129.129 Up CP 00:00:49 0200.0afa.8181   -- VIP_VTEP BGW 1st site
You use nexus so I hope I direct you correctly
Now for multisite you need to use
Fabric site-id xxx
This will use in type6 of evpn which use for BUM between sites
Try use this command and check
MHM
My NXOS software image file is: bootflash:///nxos64-cs.10.4.2.F.bin, in what mode is this command "Fabric site-id xxx" entered. This is the first time I hear about it.
evpn multisite border-gateway 64601
This site-id are yoh use same in both GW of sites?
MHM
Yes, it is different on both sides.
show bgp l2vpn evpn route-type 6
Share this from both GW NSK of both sites
MHM
I don't have route-type 6 on BGW, because I use ingress replication between sites.
Forget that
show nve internal bgp evpn multisite flooding <<- share this
Also run DCI-track (I dont think it prevent loop but let see it effect in our case)
Also the link between two site config it as L3 port
MHM
I don't have this command in NXOS: show nve internal bgp evpn multisite flooding
About tracking - it is:
ams-bgw-1# sh nve multisite fabric-links
Interface State
Ethernet1/1 Up
ams-bgw-1# sh nve multisite dci-links
Interface State
Ethernet1/6 Up
evpn multisite dci-tracking <<- this need
I will check split horizon command it hidden so add it and press enter
MHM
delay-restore time 30
df-election time 3.0
split-horizon per-site
Result is same. There is loop of arp request and +14 byte every time to trailer in ethernet frame.
