Cisco Nexus 5010 ERROR: Module type doesn't support this CLI
beta_admin66
Level 2
Level 2
Hello together,
I have inserted  the Expansion module N5K-M1008 in the Cisco Nexus 5010.
I would like to set the ports with the command:
#Slot 2
#port 1-8 type ethernet
Then Comes the Output: ERROR: Module type doesn't support this CLI
Can you help me?
Thanks.
Sergiu.Daniluk
Hi @beta_admin66
The error you receive is expected since N5K-M1008 module has only FC ports:
N5K-M1008(=)
Cisco Nexus 5000 1000 Series Module 8xFC 4/2/1 (Requires SFP)
Reference: https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5020-switch/product_bulletin_c25-462134.html
Sergiu
Mosasa
Level 2
Level 2
Okay, so I did the same as OP did but instead to the correct port type: FC. And I still got the error
what gives?
