interface does not showing in cli
moosas001
before shutting down all the  interface  was working
once  shutdown and
started  cisco Nexus9000 C9508 does not show iany physical  nterface
sh int status  does not list any physical interfaces
Show module  1 does not show any interface  as if there is no modules installed
(it is not visible in the cli)
please  see  the  attched
Please help
Hi!
Which NX-OD Version are you running?
What happens if you try to..?:
conf t
int eth 1/10
no shut
Can you try to reseat the module (unplug it for a second and then re-plug it)?
Thanks and br
Juls
Sergiu.Daniluk
Hi @moosas001
Check the "show logging log" for any syslog messages which could indicate the problem.
Stay safe,
Sergiu
