04-29-2025 07:09 AM
I am trying to add 2 vrfs to Nexus asuming that there are 2 different tenants connected to my leaf in EVPN VXLAN network. The thing is even when I add the second vpn, BGP only show one l2vni and the second vpn does not forward. Here is the configuration of one of the leafs and the next one is almost the same. Now is this a problem on EVE-NG or am I missing something?
L211# sh run
nv overlay evpn
feature bgp
feature pim
feature isis
feature fabric forwarding
feature interface-vlan
feature vn-segment-vlan-based
feature nv overlay
ip pim rp-address 2.2.2.2 group-list 224.0.0.0/4 bidir
ip pim ssm range 232.0.0.0/8
vlan 1,10,102,1001-1002
vlan 10
vn-segment 10010010
vlan 102
vn-segment 10020102
vlan 1001
vn-segment 10011001
vlan 1002
vn-segment 10021002
route-map ALL_DIRECT_PREFIXES_C1001 permit 10
route-map ALL_DIRECT_PREFIXES_C1002 permit 10
vrf context C1001
vni 10011001
rd auto
address-family ipv4 unicast
route-target both auto
route-target both auto evpn
vrf context C1002
vni 10021002
rd auto
interface Vlan10
no shutdown
vrf member C1001
ip address 10.0.10.211/24
interface Vlan102
no shutdown
vrf member C1002
ip address 10.0.102.211/24
ip pim sparse-mode
interface Vlan1001
no shutdown
vrf member C1001
ip forward
interface Vlan1002
no shutdown
vrf member C1002
ip forward
interface nve1
no shutdown
host-reachability protocol bgp
source-interface loopback0
member vni 10010010
mcast-group 229.0.0.10
member vni 10011001 associate-vrf
member vni 10020102
mcast-group 229.0.1.102
member vni 10021002 associate-vrf
interface Ethernet1/1
no switchport
mtu 9216
ip address 10.221.211.1/31
ipv6 address use-link-local-only
no isis hello-padding always
isis network point-to-point
ip router isis DC2
ip pim sparse-mode
no shutdown
interface Ethernet1/2
no switchport
mtu 9216
ip address 10.222.211.1/31
ip router isis DC2
ip pim sparse-mode
no shutdown
interface Ethernet1/30
switchport mode trunk
spanning-tree port type edge trunk
interface loopback0
ip address 2.0.0.211/32
ipv6 address 2001::211/128
ip router isis DC2
ip pim sparse-mode
icam monitor scale
router isis DC2
net 00.0000.0000.0211.00
is-type level-2
router bgp 2
neighbor 2.0.0.221
remote-as 2
update-source loopback0
address-family l2vpn evpn
send-community
send-community extended
neighbor 2.0.0.222
remote-as 2
send-community
vrf C1001
redistribute direct route-map PERMIT_CONNECTED_C1001
vrf C1002
redistribute direct route-map PERMIT_CONNECTED_C1002
evpn
vni 10010010 l2
rd auto
route-target import auto
route-target export auto
vni 10020102 l2
rd auto
L211# sh bgp l2 ev
BGP routing table information for VRF default, address family L2VPN EVPN
BGP table version is 5, Local Router ID is 2.0.0.211
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - b
est2
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 2.0.0.212:3
*>i[5]:[0]:[0]:[24]:[10.0.20.0]/224
2.0.0.212 0 100 0 ?
Route Distinguisher: 2.0.0.211:3 (L3VNI 10011001)
*>l[5]:[0]:[0]:[24]:[10.0.10.0]/224
2.0.0.211 0 100 32768 ?
2.0.0.212 0 100 0 ?
L211# sh nve vni
Codes: CP - Control Plane DP - Data Plane
UC - Unconfigured SA - Suppress ARP
SU - Suppress Unknown Unicast
Xconn - Crossconnect
MS-IR - Multisite Ingress Replication
HYB - Hybrid IRB mode
Interface VNI Multicast-group State Mode Type [BD/VRF] Flags
nve1 10010010 229.0.0.10 Up CP L2 [10]
nve1 10011001 n/a Up CP L3 [C1001]
nve1 10020102 229.0.1.102 Up CP L2 [102]
nve1 10021002 n/a Up CP L3 [C1002]
L211# sh int nve1
nve1 is up
admin state is up, Hardware: NVE
MTU 9216 bytes
Encapsulation VXLAN
Auto-mdix is turned off
RX
ucast: 0 pkts, 0 bytes - mcast: 0 pkts, 0 bytes
TX
ucast: 16 pkts, 1770 bytes - mcast: 0 pkts, 0 bytes
06-22-2025 09:03 AM
Are this issue solved
MHM
