Problem with vPC-HM vlan configuration
yingguan
In Nexus1000v, the "VM-Uplink" ethernet port profile is set to "switchport truck allowed vlan 861-863" which is using vPC-HM with four vmnics, two sub-groups, two links to one upstream, and two for the another upstream switch . But on vCenter -> Home -> Inventory -> Networking -> then select the "Uplink" profile on left column of vSphere, then select "Ports" tab on main window, it shows three vmnics within under "VM-Uplink" profile show VLAN access:861-863, but one vmnics shows VLAN access: 1.
Supposed all vmnics within that port profile will show the same VLAN access:861-863. We fould that by removed and then re-add vmnic to that port profile "VM-Uplink", the VLAN status resumed normal  from VLAN 1 back to VLAN 861-863.
It is still unknown about how to trigger this.
Robert Burns
Please paste your running config.  Feel free to remove any sensitive information.
Robert
Here is the config.
Thanks.
Darren
version 4.2(1)SV1(4a)
no feature telnet
no feature http-server
feature tacacs+
username admin password 5 $XXXXXXX  role network-admin
banner motd #Nexus 1000v Switch#
ssh key rsa 2048
ip domain-lookup
ip domain-lookup
tacacs-server key 7 "XXXXXXXX"
tacacs-server host X.X.X.X
aaa group server tacacs+ tacacs
    server X.X.X.X
    use-vrf management
    source-interface mgmt0
switchname N1000V-03
ip access-list SNMP_TO_NMS
  10 permit ip X.X.X.X/32 any
  20 permit ip X.X.X.X/32 any
  30 permit ip X.X.X.X/32 any
  40 permit ip X.X.X.X/32 any
  50 permit ip X.X.X.X/32 any
vem 3
  host vmware id 35383339-3134-5347-4831-323058413135
vem 4
  host vmware id 35383339-3134-5347-4831-323058413133
vem 5
  host vmware id 34393433-3239-5347-4830-31395844324d
vem 6
  host vmware id 34393433-3239-5347-4830-313958443253
snmp-server source-interface trap loopback0
snmp-server source-interface inform loopback0
snmp-server user admin network-admin auth md5 X.X.X.X priv X.X.X.X localizedkey
snmp-server host X.X.X.X traps version 2c XXXXX
snmp-server community XXXXX group network-operator
snmp-server community XXXXX use-acl SNMP_TO_NMS
ntp server X.X.X.X prefer
aaa authentication login default group tacacs
aaa authentication login console local
vrf context management
  ip route 0.0.0.0/0 X.X.X.X
vlan 1,844,851,861-863,871-878
port-channel load-balance ethernet source-dest-ip-vlan
port-profile default max-ports 253
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  max-ports 32
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  max-ports 32
  state enabled
port-profile type ethernet VEM-Uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 851
  cdp enable
  speed 1000
  duplex full
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 851
  max-ports 32
  description Connection to VSM
  state enabled
port-profile type ethernet UTM-VLAN-Uplink
  vmware port-group
  switchport trunk allowed vlan 861-863
  channel-group auto mode on sub-group manual
  no shutdown
  max-ports 32
  description Uplink profile for vlan 861-863 traffic
  state enabled
port-profile type ethernet NetBackup-Uplink
  vmware port-group
  switchport trunk allowed vlan 844
  no shutdown
  max-ports 32
  description Uplink profile for NetBackup-Uplink
  state enabled
port-profile type ethernet FW-VLAN-Uplink
  vmware port-group
  switchport trunk allowed vlan 871-878
  no shutdown
  max-ports 32
  description Uplink profile for FW-VLAN-Uplink
  state enabled
port-profile type vethernet VLAN-861
  vmware port-group
  switchport mode access
  switchport access vlan 861
  no shutdown
  state enabled
port-profile type vethernet VLAN-862
  vmware port-group
  switchport access vlan 862
  no shutdown
  state enabled
port-profile type vethernet VLAN-863
  vmware port-group
  switchport access vlan 863
  no shutdown
  state enabled
port-profile type vethernet VLAN-844
  vmware port-group
  switchport access vlan 844
  no shutdown
  description NetBackup Network
  state enabled
port-profile type vethernet VLAN-871
  vmware port-group
  switchport access vlan 871
  no shutdown
  state enabled
port-profile type vethernet VLAN-872
  vmware port-group
  switchport access vlan 872
  no shutdown
  state enabled
port-profile type vethernet VLAN-873
  vmware port-group
  switchport access vlan 873
  no shutdown
  state enabled
port-profile type vethernet VLAN-874
  vmware port-group
  switchport access vlan 874
  no shutdown
  state enabled
port-profile type vethernet VLAN-875
  vmware port-group
  switchport access vlan 875
  no shutdown
  state enabled
port-profile type vethernet VLAN-876
  vmware port-group
  switchport access vlan 876
  no shutdown
  state enabled
port-profile type vethernet VLAN-877
  vmware port-group
  switchport access vlan 877
  no shutdown
  state enabled
port-profile type vethernet VLAN-878
  vmware port-group
  switchport access vlan 878
  no shutdown
  state enabled
vdc SVTN1000V-03 id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 32 maximum 32
  limit-resource u6route-mem minimum 16 maximum 16
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
  inherit port-profile UTM-VLAN-Uplink
  vem 3
  description XXXXXXXX-07 UTM-VLAN-Uplink
interface port-channel2
  inherit port-profile VEM-Uplink
  vem 3
  no shutdown
interface port-channel3
  inherit port-profile FW-VLAN-Uplink
  vem 3
  description XXXXXXXX-07 FW-VLAN-Uplink
interface port-channel4
  vem 4
interface port-channel5
  vem 4
  description XXXXXXXX-06 UTM-VLAN-Uplink
interface port-channel6
  vem 4
  description XXXXXXXX-06 FW-VLAN-Uplink
interface port-channel7
  vem 5
  description XXXXXXXX-03 FW-VLAN-Uplink
interface port-channel8
  vem 5
interface port-channel9
  vem 5
  description XXXXXXXX-03 UTM-VLAN-Uplink
interface port-channel10
  vem 6
  description XXXXXXXX-04 FW-VLAN-Uplink
interface port-channel11
  vem 6
interface port-channel12
  vem 6
  description XXXXXXXX-04 UTM-VLAN-Uplink
port-channel cdp-map XXXXXXXXXXXX 0
interface mgmt0
  ip address XXXXXX/24
interface loopback0
  ip address XXXXXX/32
interface Vethernet1
  inherit port-profile VLAN-871
  description XXXXXX, Network Adapter 1
  vmware dvport 1500 dvswitch uuid "XXXXXX"
  vmware vm mac XXXXXX
interface Vethernet2
  inherit port-profile VLAN-862
  vmware dvport 626 dvswitch uuid "XXXXXX"
interface Vethernet3
  vmware dvport 256 dvswitch uuid "XXXXXX"
interface Vethernet4
  vmware dvport 258 dvswitch uuid "XXXXXX"
interface Ethernet3/8
  description XXXXXXXX-07 VEM-Uplink-XXXXXX
interface Ethernet3/9
  description XXXXXXXX-07 UTM-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet3/10
  sub-group-id 1
interface Ethernet3/12
  description XXXXXXXX-07 FW-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet3/13
  sub-group-id 2
interface Ethernet3/14
  sub-group-id 2
interface Ethernet3/15
interface Ethernet3/16
  sub-group-id 2
interface Ethernet4/8
  description XXXXXXXX-06 VEM-Uplink-XXXXXX
interface Ethernet4/9
  description XXXXXXXX-06 UTM-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet4/10
  sub-group-id 1
interface Ethernet4/12
  description XXXXXXXX-06 FW-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet4/13
  sub-group-id 2
interface Ethernet4/14
  sub-group-id 2
interface Ethernet4/15
interface Ethernet4/16
  sub-group-id 2
interface Ethernet5/8
  description XXXXXXXX-03 VEM-Uplink-XXXXXX
interface Ethernet5/9
  description XXXXXXXX-03 UTM-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet5/10
  sub-group-id 2
interface Ethernet5/12
  description XXXXXXXX-03 FW-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet5/13
  sub-group-id 1
interface Ethernet5/14
  sub-group-id 2
interface Ethernet5/15
interface Ethernet5/16
  sub-group-id 2
interface Ethernet6/8
  description XXXXXXXX-04 VEM-Uplink-XXXXXX
interface Ethernet6/9
  description XXXXXXXX-04 UTM-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet6/10
  sub-group-id 2
interface Ethernet6/12
  description XXXXXXXX-04 FW-VLAN-Uplink-XXXXXX
  sub-group-id 1
interface Ethernet6/13
  sub-group-id 1
interface Ethernet6/14
  sub-group-id 2
interface Ethernet6/15
interface Ethernet6/16
  sub-group-id 2
interface control0
clock timezone HKT 8 0
line vty
  exec-timeout 5
line console
  exec-timeout 1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-2
svs-domain
  domain id 3841
  control vlan 851
  packet vlan 851
  svs mode L2
svs connection VC
  protocol vmware-vim
  remote ip address X.X.X.X port 80
  vmware dvs uuid "5b 58 39 50 6e 16 ef de-e1 8a 45 84 07 c5 7b 32" datacenter-name XXXXXX
  max-ports 8192
  connect
vsn type vsg global
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
N1000V-03# exit
