Switch Port Errors (with no further description)
-meb
I`m trying to figure out why the port on my switch is showing 842 under errors column but when on the screen below yet when I run a;
show logging
I dont see that same error. I have replaced cables, run direct from device to switch, SFPs and keeps showing. Any idea as to what I`m missing here?
2023 Dec 13 09:09:32 switch1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN50%$ Interface fc1/18 is down (Link failure loss of signal) device1
2023 Dec 13 09:11:07 switch1 %PORT-5-IF_UP: %$VSAN50%$ Interface fc1/18 is up in mode F device1
2023 Dec 13 09:12:29 switch1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN50%$ Interface fc1/18 is down (Link failure loss of signal) device1
2023 Dec 13 09:13:53 switch1 %PORT-5-IF_UP: %$VSAN50%$ Interface fc1/18 is up in mode F device1
2023 Dec 13 09:24:57 switch1 %PORT-5-IF_DOWN_NOS_RCVD: %$VSAN50%$ Interface fc1/18 is down (NOS received) device1
2023 Dec 13 09:25:01 switch1 %PORT-5-XCVR_REMOVED: Interface fc1/18 transceiver removed (DS-SFP-FC16G-SW, AVJ2150JC78)
2023 Dec 13 09:25:26 switch1 %PORT-5-XCVR_DETECTED: Interface fc1/18 transceiver detected (DS-SFP-FC8G-SW, AVD1848BB3H)
2023 Dec 13 09:25:28 switch1 %PORT-5-IF_UP: %$VSAN50%$ Interface fc1/18 is up in mode F device1
2023 Dec 13 09:32:10 switch1 %LIBIFMGR-5-INTF_COUNTERS_CLEARED: Interface fc1/18, counters cleared by user
2023 Dec 13 10:47:40 switch1 %PORT-5-IF_DOWN_LINK_FAILURE: %$VSAN50%$ Interface fc1/18 is down (Link failure loss of signal) device1
2023 Dec 13 11:00:31 switch1 %PORT-5-IF_UP: %$VSAN50%$ Interface fc1/18 is up in mode F device1
Thank you
0 Replies 0
