Showing results forĀ
Search instead forĀ
Did you mean:Ā
Persistant chat configuration with postgres DB
yogeshshanbhag
Community Member
Hi Team,
I was able to complete the setup of Postgres DB and configure it to CUPS (for Persistant chat) as per the steps mentioned in the link given below.
Database Setup Guide for Cisco Unified Presence Release 8.0, 8.5 and 8.6 - Configuring an External Database on Cisco Uni…
I see that the checks 'Ping External DB' and ' Connectivity to External DB' both pass. I also see the tables created in the postgres database schema.
The issue I am facing is that the insert statements that persist the chat messages are failing (invalid syntax as per the postgres DB logs).
The sql statement looks like:
INSERT INTO tc_msgarchive(msg_id, to_jid, from_jid, nick_jid, sent_date, msg_type, body_len, message_len, body_string, message_string, body_text, MESSAGE_TEXT, subject)
VALUES('1',
       '[email protected]',
       '[email protected]/[email protected]/jabber_1111',
       '2014-05-12 08:32:13.839975',
       'g',
       4,
       469,
       'test',
       '<message from=\'[email protected]/jabber_1111\' id=\'uid:5359230a:000049ec:00000679\' to=\'[email protected]\' type=\'groupchat\' xml:lang=\'en\'><body>test</body><html xmlns=\'http://jabber.org/protocol/xhtml-im\'>..........</message>'
ERROR:  syntax error at or near "user1" at character 417
The error is because of the '\' (backslash) which is escaping the " ' " single quote in the <message> tag.
If I change the '\' backslash to " ' " , the insert query works fine.
<message from=''[email protected]/jabber_1111''
Is anyone facing this issue with postgres DB for chat persistance setup? Is there a way to tell CUPS to use " ' " (single quotes) instead of '/' (backslash).
tinghche
Level 6
Level 6
Hi Yogesh,
You need to edit the postgressql.conf for the following attribute
escape_string_warning = off
http://www.postgresql.org/docs/8.2/static/runtime-config-compatible.html#GUC-ESCAPE-STRING-WARNING
And maybe this as well
backslash_quote = on/off
http://www.postgresql.org/docs/8.2/static/runtime-config-compatible.html#GUC-BACKSLASH-QUOTE
Howard
tinghche
Level 6
Level 6
Hi Yogesh,
Howard
Yes I found the information in the link, forgot to update the message.
Instant Messaging Compliance Guide for Cisco Unified Presence Release 8.0, 8.5 and 8.6 - Planning for IM Compliance [Cis…
Thanks Howard.
