add admins to meraki dashboard
Dan_W
We need to add quite a few admins to meraki dashboard. I can add the admins from the dashboard but its very time consuming.
Wondering if there is a quicker way to add the admins.
Thank you
-Dan
omz
The only way you could make your life easy is by utilising the Meraki API.
Please have a look at the Meraki API docs -
https://developer.cisco.com/meraki/
There is already a Python script available to add/remove admins via API -
https://developer.cisco.com/meraki/build/manage-administrators-across-organizations/
hope this helps
please don't forget rate any helpful posts
omz
hope this helps
ok thanks
I am not up to speed with Python but I guess I will have to give it a go.
-Dan
with some help from a colleague we are able to use the script to add users
thanks for your help
-Dan
