Ansible using Loop with registered variables
Netmart
Level 7
Level 7
I was wondering, whether it is possible instead of creating three separate tasks, one processing one element of an array, to actually loop through an array.
Example:
vars:
      ansible_become_pass: "{{ vault_sudo_password }}"
      ansible_python_interpreter: /usr/bin/python3
      prefix:
         -  10.0.1.0/25
         -  10.0.3.0/25
         -  10.0.5.0/25
     - name: Task1- remove prefix
       ios_config:
         commands:
             - no ip prefix-list MTDC-nets permit {{prefix[0]}}
       when: output2.stdout is search ~prefix[0]
       become: true
       register: output1
     - name: Task2- remove prefix
       ios_config:
         commands:
             - no ip prefix-list cisco-nets permit {{prefix[1]}}
       when: output2.stdout is search ~prefix[1]
       become: true
       register: output2
     - name: Task3- remove prefix
       ios_config:
         commands:
             - no ip prefix-list MTDC-nets permit {{prefix[2]}}
       when: output2.stdout is search ~prefix[2]
       become: true
       register: output3
Is it possible to create only one task and looping through the elements of an array:
  vars:
      loop:
         -  10.0.1.0/25
         -  10.0.3.0/25
         -  10.0.5.0/25
register: prefix
       ios_config:
         commands:
             - no ip prefix-list Cisco-nets permit {{prefix}}
       become: true
       register: output1
19 Replies 19
Sorry Torbjoern, this has been already tried without success.
Is there no example available illustrating looping through an array as in my case.
The material I"ve found so far in Ansible is not really matching what I am looking for.
The closest I was able to find has been:
Iterating over a list of hashes
If you have a list of hashes, you can reference subkeys in a loop. For example:
- name: Add several users
  ansible.builtin.user:
    name: "{{ item.name }}"
    state: present
    groups: "{{ item.groups }}"
  loop:
    - { name: 'testuser1', groups: 'wheel' }
    - { name: 'testuser2', groups: 'root' }
https://docs.ansible.com/ansible/latest/playbook_guide/playbooks_loops.html
Netmart
Level 7
Level 7
Hi Torbjorn,
I am sorry, it is still failing.
I also tried the following:
       ios_config:
         commands:
             - "no ip prefix-list {{ item.network }} permit {{ item.prefix }}"
       loop:
               - network:"Test-nets",prefix:"10.0.0.0/25"
               - network:"Test-nets",prefix:"10.0.2.0/25"
               - network:"Test-nets",prefix:"10.0.5.0/25"
However, Ansible is still complaining that has no attribute network and prefix. And following the Ansible documentation, the loop is configured underneath the task.
fatal: [switch: FAILED! => {"msg": "The task includes an option with an undefined variable. The error was: 'ansible.parsing.yaml.objects.AnsibleUnicode object' has no attribute 'network'. 'ansible.parsing.yaml.objects.AnsibleUnicode object' has no attribute 'network'\n\nThe error appears to be in '/home/cisco/Ansible/library/lib-ios-xe-staging/site-ios-xe-CE-bgp-prefix-list-update-loop2.yml': line 34, column 8, but may\nbe elsewhere in the file depending on the exact syntax problem.\n\nThe offending line appears to be:\n\n\n     - name: Task3- remove prefix\n       ^ here\n"}
Netmart
Level 7
Level 7
Sorry, still the same.
Extract Playbook:
       ios_config:
         commands:
       loop:
               - { network:"Test-nets",prefix:"10.0.0.0/25" }
               - { network:"Test-nets",prefix:"10.0.2.0/25" }
               - { network:"Test-nets",prefix:"10.0.5.0/25" }
The previous setup follows the example as illustrated in the Ansible documentation. The only difference that I am using the ios_config command to iterate a command with a loop variable.
    state: present
  loop:
netmart2
Level 2
Level 2
After reviewing it together with someone from Ansible Community, it turned out that the syntax for loop was not correct:
A space is needed after each ‘:’ and ‘,’ in the dictionary. Tip: use ``` before and after a block of YAML/code to make it easier to read.
It is working as followed:
 - ios_config:
     commands:
   loop:
     - { network: Test-nets, prefix: "10.0.0.0/25" }
     - { network: Test-nets, prefix: "10.0.2.0/25" }
     - { network: Test-nets, prefix: "10.0.5.0/25" }
netmart2
Level 2
Level 2
The same is illustrated in Ansible documetation:
    state: present
  loop:
