Certifications and Skills
dglztcisco
Hi everyone,
I’m trying to determine the most recommended path to follow in terms of certifications and skills development, especially in the areas of networking, network programmability, and automation. With the growing importance of technologies like Intent-Based Networking (IBN), APIs, and DevOps practices in networking, I’m unsure where to focus my efforts first.
For those who have experience, what would you recommend as the best starting point? Should I prioritize traditional networking certifications (like CCNA/CCNP), dive directly into programmability-focused certifications (such as DevNet Associate), or balance both areas? Additionally, are there specific programming languages or tools (e.g., Python, Ansible, YANG, REST APIs) that are essential to master early on?
Any advice or insights on structuring a learning path would be greatly appreciated!
Welcome @dglztcisco - IMO, you cannot automate, what you do not know, so I would start with the CCNA if this is your first look at networks, understanding how to set up and build networks is critical if you plan on working on them. Many refer to this as the basics and teh first step on this journey to more advanced areas which you mentioned. Get this down first and then you can expand into automation/devops as you noted.
15% of your total score for the 200-901 DEVASC v1.1 is networking, so you will be ready by passing your CCNA if you go to this exam. You can go into this exam with zero automation and programming skills, although some have found it more useful to take a Python course first, such as the Cisco PRNE course (others are out there too), but this exam will show you all the automation side you mentioned.
You could always run the theory of devops along side your CCNA, books like DevOps for Dummies, The DevOps Handbook are great reading and give you knowledge on Agile, continuous delivery, Integrating security, change management, and compliance etc.. There is a ton out there now on this.
Check the learning content on https://developer.cisco.com/ and also look at Cisco U as well, as this offers the complete paths, packages and study material.
Hope this helps, best of luck!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
