pyats learning bgp
josecarvalho
Frequent Visitor
Frequent Visitor
  I wanted to know if there was a way for pyats to only look at specific vrf rather than all BGP tables in on a router.  current; pyats learn bgp --testbed-file wan_router.yaml --output current  wanted; pyats learn bgp --vrf xxx --testbed-file wan_router.yaml --output current
2 Accepted Solutions
atiqbay023
Visitor
I think you need to use the `--config` option to specify the VRF in your command. You can use a workaround by creating a custom configuration file that includes the desired VRF. Here’s a basic example:
1. Create a custom YAML configuration file specifying the VRF:
bgp:
properties:
vrfs:
- name: xxx
2. Use this configuration file in your `pyats learn` command:
pyats learn bgp --testbed-file wan_router.yaml --config vrf_config.yaml --output current
Replace `vrf_config.yaml` with the path to your custom configuration file. This setup ensures `pyats` focuses on the specified VRF.
Ruben Cocheno
@josecarvalho
yes, you must specify than on the yaml
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Guess you would use  --vrf <VRF_NAME>: This is the new argument you're adding. Replace <VRF_NAME> with the actual name of the VRF you want to target.
pyats learn bgp --vrf <VRF_NAME> --testbed-file wan_router.yaml --output current
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
atiqbay023
Visitor
bgp:
properties:
vrfs:
- name: xxx
Ruben Cocheno
@josecarvalho
