07-24-2025 07:48 AM
This API Request no longer works with vManage Version 20.15
/dataservice/system/device/vedges?system-ip=10.255.255.86
This used to work prior to version 20.15, I have many of my scripts using it
I can get device information using this request:
But then I need to narrow it down to a specific device by using the system IP, but it fails
https://vmanage-xxxxxx.sdwan.cisco.com:443 "GET /dataservice/system/device/vedges?system-ip=10.255.255.86 HTTP/1.1" 400 None
Solved! Go to Solution.
07-25-2025 05:48 AM
I think you need to use GET /dataservice/device?system-ip=10.255.255.86
Per https://developer.cisco.com/docs/sdwan/20-15/device-inventory/#connect-devices
07-25-2025 05:48 AM
07-25-2025 09:35 AM - edited 07-25-2025 09:35 AM
Thank you @bigevilbeard
This seems to work
They must have changed it in version 20.15, since I used to send the following API to get the device info:
07-25-2025 09:46 AM
Sure thing glad you are sorted. From what I read and did some digging..
The endpoint worked up to vManage 20.9.x but was deprecated afterward.
By 20.12, Cisco began transitioning to a new API structure.
In 20.15, the old endpoint was fully disabled, returning HTTP 400 errors.
