Device development using ESS-3300 Switches
Utis/Ilya
Community Member
Good day!
I am developing highly explosion-proof equipment using ESS-3300- (24T) -CON-E switches.
The switch will be used at category mines.
The hardware technical guide has a link to Reference Design for correct product design.
For example, the features of the use of a shift register for LED indication.
What steps do I need to take to gain access to the design documents, in particular to obtain the Reference Design?
Best regards, Ilya
@Utis/Ilya try this link https://www.cisco.com/c/en/us/solutions/enterprise/design-zone-industry-solutions/index.html - if you cannot find the document required - contact your Cisco Account Manager who will be able to help.
BR
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
