Discovering Stacked Switches using SNMP
rthomas2
We produce a monitoring / management platform which, amongst other things, talks to Cisco devices using SNMP.
In the past we've used the CISCO-STACK-MIB to discover switch configurations for 2900-series boxes etc but we're now coming across 3850 stacked switches which are a problem, for two reasons : (a) they don't conform to the usual Slot/Port model, but introduce a 'third dimension' to give a Module/Slot/Port architecture (eg an interface will be named GigabitEthernet3/1/12 for Module3, Slot 1, Port 12), and (b) they don't support the 'Stack' MIB.
My Question is - is there another SNMP MIB that the 3850-series switches support, which enables an SNMP manager to discover the structure of the device - modules, slots, ports etc, and map these to entries in the ifTable so we can check health on them ?
I've found the 'stackwise' MIB but that just gives me a list of modules with power management data etc.
Any help much appreciated...
brylevin
if you could run an snmpwalk on the box you have and post some of the oid's that come back (assuming that you have some of the mibs loaded) I could look in the Big Box of Cisco Mibs I have and see if those oid's are listed in my mibs.txt folder.
