Elearning Coding 101 - REST APIs - problems at Python for the installation of module Requests
info
Community Member
15maerz2017 Filip Cisco Technical Support Tel. 0800 179 317 - Cisco Systems (Schweiz) GmbH, Richtistrasse 7, 8304 Wallisellen/ZH, Tel. 0800 179 317, ref:_00DA0H3hn._50015ZsXc3
Referenzen:
1-First of all open Tutorial instead original URL
https://developer.cisco.com/site/devnet/learn/coding-101-tutorial/index.gsp
2-Original URL:
https://learninglabs.cisco.com/tracks/apic-em-prog/programming-found/coding-101-rest-basics-ga/step/1
3-This part of the documentation covers the installation of Requests. The first step to using any software package is getting it properly installed:
http://docs.python-requests.org/en/latest/user/install/#install
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Dear Support,
I need support to Setup your Python Environment at Referenz 1 above.
My Problem is that I have dificulties at Python for the installation and import of Module Requests. and that the documentation is not functioning properly at Referenzen 3.
Freundliche Grüsse
Alfredo Rey
Hofwies 13
CH-8906 Bonstetten/ZH
Tel. 044 737 47 20
Natel 076 398 86 79
Email [email protected]
Web www.datarey.ch
Cisco ID CSCO13121747
brtiller
Level 4
Level 4
Hi Alfredo,
The coding 101 lab in our learning labs web site doesn't require the Request module for Python since all of the REST API examples shown there are handled via the HTTP client Postman.  Regarding the coding 101 tutorial, that's a separate item not to be linked with the lab.
That said, if you are having trouble getting the Requests module installed, we do have steps for you in our Coding 102 lab.  On the top page of the lab click on 'How to Setup Your Own Computer'.  If you are having trouble installing Python, please consult  the vendor provided instructors at https://www.python.org .
Brett
