Finesse CORS with Dialogs
chunhsuchen
Community Member
Hi:
I need to make Finesse calls for an UI app and I am getting CORS problem.
My calls with User API worked.
PUT https://uccx01.com:8445/finesse/api/User/myUserName
Content-Type: application/xml
Authorization: Basic abcdefghijklmnopq -- this is base64 encoded username/password
     <User><state>LOGIN</state><extension>7748</extension></User>
But my Dialog api call failed.  This is my MakeCall.
POST https://uccx01.com:8445/finesse/api/User/myUserName/Dialogs
    <Dialog><requestedAction>MAKE_CALL</requestedAction><fromAddress>7748</fromAddress><toAddress>7746</toAddress></Dialog>
The error message is:
Failed to load https://uccx01.com:8445/finesse/api/User/myUserName/Dialogs: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://localhost' is therefore not allowed access. The response had HTTP status code 401.
I tried including Origin in the above header but still got the same error.
Origin : http://localhost
Any help appreciated. Thanks
chunhsuchen
Community Member
I found my problem. My requestOption was not correctly set. Please ignore this question.
