for developing the client using iec 61850 java library
josecarvalho
Frequent Visitor
Frequent Visitor
To develop Java applications that support the IEC 61850 protocol. Can I get a java library from cisco to support this?
Ruben Cocheno
@josecarvalho
I don’t think that you get something in java, likely in Python and you need to build your own Java library.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@josecarvalho
