How do I parse firewall configuration
xinhuan_zheng
Community Member
I have Cisco ASA Firewall configuration. We typically save the configuration in text format. Is there an easy way to parse the configuration to extract all Object Network information & output in CSV format? The CSV format I'd like is:
NAME, DESCRIPTION, TYPE, IP, NETMASK
TEST, TEST HOST, HOST, 1.2.3.4, 255.255.255.255
Do I need to write my own parsing program to do that? We also have Cisco Firewall Management Center. Can I accomplish it using FMC?
Asmat Sulaiman
Hi Xinhuan,
You can simply use a command "show running-config object in-line" this will provide the output you need. Hope this help
5 Replies 5
KyoCode
Level 2
Level 2
If you're currently using ASDM, you can download all of them with a right click to CSV, if you need an automation, you might want to download the API bundle and install it. Please, keep me posted which one do you need.
Also, I've created this code a long time ago that will connect to the FMC RestAPI and download the ACP to a csv file: https://github.com/AngelIV23/cisco-fmc-excel-from-json
try it out and let me know
KyoCode
Level 2
Level 2
I just saw my code and I think is a little frustrating to see so many errors, let me update it
Asmat Sulaiman
Hi Xinhuan,
That's what I need. Thank you!
I'm glad that helped.
