Do I need transport input ssh for automation?
YazeedAshrafi
I'm going to setup automation system
(transport input ssh) command is it helping to be a good automation or I need it to have it for connectivity?
5 Replies 5
@YazeedAshrafi yes you would need it for automation purposes, you'd also want it to remotely connect to the device for management purposes.
yes. if your automation service (most of the times) using SSH to connect to device.
Good luck
KB
My question is about only this command (transport input ssh), I have to use this command?
Knowing I new all the commands for ssh connectivity.
yes. better avoid unencrypted transports like telnet. using that command you only enabling SSH to connect with devices
Good luck
KB
What I mean if I didn't add this command the automation system would make connectivity with out it?
